    Draw non-radial tri and quad faced spheres - how to create?
    22 Posts 8 Posters 4.2k Views 8 Watching
    • brookefoxB
      brookefox
      Variety is the spice of life and a well stocked draw menu is enabling feeling.
      My main reason is that I'm looking for more equally sized mesh faces, though I guess there are other good reasons.
      Basics Q: Quads or tris when modeling?
      "The sphere on the left has 360 faces, the one on the right has 320 faces.The one on the right has more curve and more uniform curve."
      http://community.secondlife.com/t5/Mesh/Basics-Q-Quads-or-tris-when-modeling/td-p/1302581
      Just interesting:
      Cubic Globes
      "Although mapping into the regular hexahedron (an ordinary cube) is prone to pronounced distortion, the nonsensical notion of "Earth-in-a-box" has long fascinated me. Once I plotted and folded such a map by hand alone, using an arbitrary compound of cylindrical and Collignon-like projections."
      (www.progonos.com)
      ~ Brooke
      • gillesG
        gilles
        http://rhin.crai.archi.fr/rld/plugin_details.php?id=156
        http://sketchup.google.com/3dwarehouse/search?uq=0058532540730737055623450&scoring=m&start=0
        Be care geodesics could drive you crazy, I know.
        • brookefoxB
          brookefox
          Thanks, Gilles.
          I've sampled Taff's wonderful models several times over the years.
          http://forums.sketchucation.com/viewtopic.php?f=79&t=40874&p=362816&hilit=geodesic#p362816
          That particular truss will only produce a sphere if 20 copies are used, rotated around the correct axes, by the correct angles. I did exactly that, in less than a minute
          ~ Brooke
          • brookefoxB
            brookefox
            Thanks to Taff, who likes to make you learn a bit...
            Now to skin it... that is, to add a skin.
            ~ Brooke
            • mitcorbM
              mitcorb
              Maybe you would like to investigate this geodesic source: http://www.cadreanalytic.com/cadregeo.htm
              Also, I assume the spheres and shapes in the Components folder that came with Sketchup are not exactly what you need?
              • gillesG
                gilles
                This plugin does this:
                3 and 2 iterations
                • brookefoxB
                  brookefox
                  Does the trick. And has been doing so since 2008.
                  You know how much time you could have saved me if you were paying more attention to my problems?
                  Perhaps I should pay better attention...
                  Thank you very much, Gilles.
                  ~ Brooke
                  • TaffGochT
                    TaffGoch
                    And that's a good thing,...
                    ...right? ๐Ÿ˜†
                    -Taff
                    "Information is not knowledge." -- Albert Einstein
                    • gillesG
                      gilles
                      Sure, but it's also a good thing to ( try to ) understand how things are made. ๐Ÿ’š
                      • thomthomT
                        I had not seen that plugin. Would have saved me some time ... a while ago ... doh!
                        • gillesG
                          gilles
                          http://rhin.crai.archi.fr/rld/index.php is another gold mine to dig in. French and English, thanks to Didier Bur. ๐Ÿ‘
                          • andybotA
                            andybot
                            Mighty big Thanks to Taff for a "making me think" moment (just posted it on the duh thread ๐Ÿ˜„ ) This is all very helpful! ๐Ÿ‘
                            • brookefoxB
                              brookefox
                              Perfect only from a distance. I wish there were a draw non-radial tri- and quad- mesh plugin, with face size/number/density settings.
                              ~ Brooke
                              • brookefoxB
                                brookefox
                                The left image in the first image is the typical SketchUp sphere construction (I call it 'radial'), the right image is what I'm looking for (I call it 'non-radial').
                                ~ Brooke
                                • thomthomT
                                  Hmm.... That plugin extends quite a few of the base SketchUp classes. Risky stuff.
                                  • brookefoxB
                                    brookefox
                                    geodesic - create sphere settings examples required text
                                    ~ Brooke
                                    • gillesG
                                      gilles
                                      I got it for a while and have no problem at this time.Of course it may be not aesthetic code, but it does the job.
                                      I know nothing about coding and I enjoy your plugins. ๐Ÿ‘
                                      • iichiversiiI
                                        iichiversii
                                        I just installed this plugin but cant find it after installation
                                        Bring on the Rain...
                                        • gillesG
                                          gilles
                                          You should find Create geodesic in the plugin menu.
                                          • iichiversiiI
                                            iichiversii
                                            Rodger that.......got it ๐Ÿ˜„
                                            • 1 / 2
