    [Plugin] Create Section Drawing V1.3(update Dec16.2012.)
    50 Posts 30 Posters 55.5k Views 30 Watching
      tulacong
      thank you huhuhu
        chooyod
        Hi tak2hata,
        How do you create a BST-Baselines on sketchup?
        Please suggest...
          tak2hata
          @chooyod said:
          Hi tak2hata,
          Please suggest...
          Hi,chooyod.
          The Group named "BST_BASELINES" will become BST-Baselines group.
          Lines/Clines in that group will be drawn as the baseline in section drawing.
          Notice: Allcharacters of "BST_BASELINES" are written in capital letters.
          by TAK2HATA
            Deportivolu
            Hi this problem
            Error: #<Errno::ENOENT: No such file or directory - C:/Users/fatiheker/Desktop/Yeni klasör/DrawingSection>
            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/create_section_drawings.rb:655:in mkdir' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/create_section_drawings.rb:655:in makeSolidSections'
            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/create_section_drawings.rb:1037
              @Faith
              The 'Yeni klasör' is the culprit.
              SketchUp's Ruby on PCs can't cope with non ASCII characters in file-/folder-names and file-paths - so do not use accented letters etc!
              Try renaming that folder 'Yeni klasoer' or 'Yeni klasor'...
              It should then work... 😕
                tak2hata
                Hi,TIG.
                Thanks for your advice!
                That is the problem of ruby in sketchup.
                Hi,Fatih.
                Please refer to that advice!
                Thanks.
                by TAK2HATA
                  LeifErik
                  I have made an Section and export it to dxf but nothing turns up in AutoCad
                  Help me fix this
                  From Leif Eriksson
                    tak2hata
                    Help me fix this
                    From Leif Eriksson
                    Hi,Leif .
                    I need to know your problem.
                    Please send me your skp file and the section dxf.
                    And tell me does this plugin work well with your other file.
                    Please start sketchup and open the skp file.
                    And show ruby console window from window menu.
                    And run this plugin.
                    Is there any error messages?
                    Please send me the messages If the error message exist.
                    I need the informations for knowing and fixing the problem .
                    Thanks.
                    by TAK2HATA
                      luqmanuel1985
                      Hy TAK2HATA,
                      i have a problem, i am using SU2013, the toolbar menu disappear,
                      when i create section from plug in menu show up notice "Here is no Section for this tool".
                      Please help me.
                        tak2hata
                        @luqmanuel1985 said:
                        Hy TAK2HATA,
                        Please help me.
                        Hi,luqmanue.
                        Does it means this plugin menu disappear in "plugins" menu?
                        or Menu bar disappear?
                        This tool has no toolbar.
                        Did you watch the tutorial video on top of this thread?
                        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=45039#p402561
                        Please place the section plane in sketchup.
                        Select it, and show pulldown menu from right click.
                        You can find the command "Section Drawing".
                        Or not select section plane ,and Select command from "Section Drawing" in "plugins" menu.
                        Thanks.
                        by TAK2HATA
                        • 3 / 3
