    DXF layer names
    3 Posts 2 Posters 245 Views 2 Watching
      saunajumal
      I'm trying to use -Sketchup to DXF and STL convertor plugin- but it takes layer names from -Entity name-. What I need is it to create layer names from definition name (the same name you give to component at first).
      I found that this part of code is related but dont know how to change it:
      #Componentinstance entity
      elsif( entity.typename == "ComponentInstance")
      if entity.name==""
      entity.name="COMPONENT"+$component_count.to_s
      $component_count+=1
      After some change I now have the code like that:
      if entity.name==""
      entity.name="LAYER NAME"
      Can anybody tell how to change it and use definition name? Plugin can be found http://www.guitar-list.com/download-software/stl-dxf-converter
        Unfortunately it's perhaps much more complex than that.
        There are several methods def dxf_.... which are expecting an argument ' layername'
        In other methods the arguments passed place say entity.name for the 'layername'
        This is then used inside the method when calling other methods thus
        dxf_write_face(entity,tform,layername)
        Since at this point we are iterating an array named ' entities' we know ' entity', so you can substitute entity**.definition**.name instead ?
        Therefore
                 if entity.name==""
                   $component_count+=1
                 others = dxf_find_faces(others, entity.definition.entities, tform * entity.transformation, entity.name,dxf_option)
              else
        becomes
                 if entity.name==""
                   $component_count+=1
                 others = dxf_find_faces(others, entity.definition.entities, tform * entity.transformation, entity.definition.name,dxf_option)
              else
        The code also renames any unnamed instances - to stop that add ### in front of the entity.name= code etc...
        This might occur more than once you need to check through >90000 lines of code...
          saunajumal
          Thanks, works perfectly for me - every component is on its own layer and CNC machine can read layers automatically for toolpaths.
