    .3ds import 2-sided materials - HELP
    7 Posts 2 Posters 601 Views 2 Watching
    • C
      coreymurray
      Hi all,
      I am trying to import a tree .3DS into SketchUp8.
      All the geometry comes in fine , but all faces with materials (leaves) have the correct texture applied to one face, but SketchUp default material applied to the other face.
      From what i can tell, the problem arises from the .3DS only having a texture defined for one face, so SketchUp just applies default to it.
      If I eyedrop one side and paintbucket it onto the other side it maps well, but only for that leaf as the other have different rotation etc.
      So i guess my options are to correct inside SketchUp, or covert to a format that has two sided mats by default or something similar then import into SketchUp.
      Any help would be greatly appreciated!
      Cheers
      Corey
      • GaieusG
        Hi Corey,
        See UV Toolkit: http://forums.sketchucation.com/viewtopic.php?t=18992
        Note however that if those leaves are not instances of the same component definition, this tree will always be a performance killer (well, it will be a performance killer even then).
        • C
          coreymurray
          Thanks so much Gaieus.
          That's a super handy little plugin โ˜บ
          Yes, the trees have come from XFrog, i'm trying to figure out a way to export the leaves as components.
          Thanks again
          Corey
          • C
            coreymurray
            BTW, how do you get the tools to show in your context menu / right click?
            • GaieusG
              That's not the context menu but the plugins menu (just the top is cropped in the screenshot)
              • C
                coreymurray
                haha- so many plugins!
                • GaieusG
                  I only use a fraction of them regularly. I "disable" many, too (renaming the extension or temporarily moving them into another folder) but when one is on the forums too much, often help with those plugins is needed and I keep many active. ๐Ÿ˜„
