    Mini-challenge
    328 Posts 26 Posters 31.4k Views 26 Watching
    • jeff hammondJ Offline
      jeff hammond
      @wo3dan said:
      @jeff hammond said:
      @dave r said:
      Oh. By using the new Arc tool.
      right. we finally have a way to natively get a rotated snap point. ...
      Is it really that accurate? I can't get it to work. If I zoom in I can still see a new endpoint (second end of arc) not being on the edge inside a group I "rotated" to(=pulled the arc to.
      as far as i can tell, it's completely accurate.. in this case, i tested it like this:
      click pic for larger
      ... then rotated the bottom board from the arc end point to the arc start point using the same center point..
      everything appears to line up perfectly for me..
      dotdotdot
      • pbacotP Offline
        I am surprised because SU can't draw real arcs.
          jeff hammond
          the arcs are the same as before. it's just that you can now get a snap at an intersection while creating the arc.
          dotdotdot
          • Wo3DanW Offline
            Wo3Dan
            The arc tool hasn't changed at all, it still doen't snap to edges, only to endpoints (say A), intersections (say A)etc. To indicate that the arc ends on a (virtual) line from certer to A.
            The tool may indicate that you slide the cursor on an edge. But when zooming in, the resulting endpoint that the arc creates isn't on the edge that it is supposed to snap to. Unfortunately!
              jeff hammond
              the old arc tool hasn't changed. there's a new arc tool in 2014.. pick the center point first then the two end points.
              try using that one.
              there's a red X indicator when an intersection is made
              dotdotdot
              • Wo3DanW Offline
                Wo3Dan
                @jeff hammond said:
                .....the old arc tool hasn't changed. there's a new arc tool in 2014.. pick the center point first then the two end points.
                try using that one.
                I did use the new arc tool (center > start endpoint > end endpoint of the arc).
                Thing is I was trying to get an intersection on a grouped edge. That didn't give me any intersection ( red X ), only a sliding rectangular red dot. But on a basic edge I did. Thank you Jeff for pointing it out.
                Have you managed to get the intersection on an edge inside a group or component?
                  jeff hammond
                  hmm.. yeah, i see what you're saying. it gets iffy when trying to achieve an intersection snap to an outside object while drawing inside a group.
                  i am (sometimes) able to get the red X depending on my zoom level.. if i zoom out of the scene, i'm more likely to get the intersection snap to an outside object.. if i'm in close to the arc's endpoint, i only seem to get the 'on edge outside active' inference.
                  dotdotdot
                  • Wo3DanW Offline
                    Wo3Dan
                    @jeff hammond said:
                    ...i am (sometimes) able to get the red X depending on my zoom level.. if i zoom out of the scene, i'm more likely to get the intersection snap to an outside object.. if i'm in close to the arc's endpoint, i only seem to get the 'on edge outside active' inference.
                    My workflow would be:
                    • copy edge (that needs to be intersected) to clipboard.
                    • enter the context where the arc neds to be draw. Then 'Paste in Place' the edge.
                    • draw the arc which now has an edge in the same context to intersect.
                    • delete (one side of) the now divided edge.
                    Or:
                    • just pre-draw a congruent edge in the same context where the arc needs to be drawn.
                    • draw the arc.
                    So no messing around with trying to find an intersection with edges in other contexts.
                    Thanks for the feedback Jeff.
                    • 13
                    • 14
                    • 15
                    • 16
                    • 17
                    • 17 / 17
