    [Question] Soap Skin & Bubble
    6 Posts 3 Posters 2.2k Views 3 Watching
    • H Offline
      Hogwarts
      I've been teaching myself to use Sketchup and using Ruby plugins including all the ones in the visual guide here on this forum.
      I haven't had any trouble as of yet. The problem I'm having is that Soap Skin will always create a "Flat" skin of my current wire frame and then I can't adjust anything.
      So I'm wondering is this normal? How am i supposed to adjust the skin ratio to make it go back to matching my wire model?
      The project I'm working on is making some artificial snow on top of a building ledge, so it has to sort of look like clouds.
      Thanks for any help you can provide on this topic.
        Does this more clear ? πŸ˜‰
        http://forums.sketchucation.com/download/file.php?id=86155&mode=view
        Take a look also to Ferrari plug
        http://forums.sketchucation.com/download/file.php?id=58250
        • H Offline
          Hogwarts
          I still can't get it to work. These tutorials are not easy to understand for a native English user.
          Thanks anyways.
          Maybe someone else can explain it better.
          • massimoM Offline
            massimo Moderator
            With the new version:
            1)Select the wire frame;
            2)Press the "Skin" button and you must have a flat subdivided surface (there you can also change the number of subdivisions by typing a value and pressing enter);
            3)Press "enter" and the mesh will adapt to the 3d wire frame.
            Then you can select the created group and apply different pressions with the "X/Y" and "Bub" buttons just by typing values and pressing enter.
            • H Offline
              Hogwarts
              Thank you, I got it working now.
              Could you also recommend any more tools similar to this but more interactive for push/pull the mesh
              Thank you.
              • massimoM Offline
                massimo Moderator
                Well never tried it, but there is also the Ferrari plugin.
                http://forums.sketchucation.com/viewtopic.php?p=286168#p286168
                Here's the link to some tutorial.
                http://forums.sketchucation.com/viewtopic.php?p=361338#p361338
                Anyway if you want something more "interactive" maybe you can combine Soap&skin (or Ferrari) and SketchyFFD.
                http://forums.sketchucation.com/viewtopic.php?p=222122#p222122
