    View hidden geometry in sp
    11 Posts 6 Posters 2.6k Views 6 Watching
    • R
      Rider
      how do we see the geometry that is hidden(like joints,etc.) in models downloaded fron
      3D Warehouse?
        You can use X-ray or Back Edges face styles as you would with any model. Look in the View menu. Keep in mind that the models downloaded from the warehouse may not have any joints to see.
        • R
          Rider
          Thanks for help.
          • TIGT
            Or use a section-plane to cut through the object to see inside it...
            • R
              Rider
              Thanks but it dosen't work!
              All the joints i the model are hidden and when i make new joints, they too hide automatically!! πŸ˜•
              • Alan FraserA
                Alan Fraser
                Make sure there aren't any hidden layers containing geometry; and turn on Hidden Geometry in the View menu. There's no reason why you shouldn't be able to see every detail of a model.
                3D Figures
                • TIGT
                  Can you post a simple example...
                    or better the object link from 3Dwarehouse πŸ˜‰
                    • R
                      Rider
                      this is the file.I downloaded it from 3D Warehouse.Try makinga joint in he model anywhere.It shall disappear automatically.And you can't get it back!I have tried every way i know (like Edit-Unhide-All,View-Hidden Geometry,etc.).But nothing works!!! ❗ ❓
                      This model is by Mr. K. It's name is "delta squad,improved".
                      Not only this!All other physics - containing - models which i have downloaded from the warehouse have the same problem! ❗
                      delta_squad.skp
                      • GaieusG
                        Open your Layer dialog (Window menu) and turn on the "Physics joints" layer (check the square box to the right).
                        Those things are obviously there to get the model "work" but as they appear, I would also put them on a hidden layer.
                        • R
                          Rider
                          Thankyou so much!!!!
                          it really worked !
                          thanks a lot
