    Writing custom aditional data in .skp
    5 Posts 4 Posters 345 Views 4 Watching
      th3lurker
      Hi again.
      I was wondering if there is anyway we can add additional data (text is sufficient) to a skp file. Data which cannot be accessed by end users, only devs who know where to look. I could use the description parameter, but that can be changed by a user.
        Yes, each Entity has an AttributeDictionaries collection where you can create AttributeDictionary objects attached to the entity
          th3lurker
          Well that was easier than expected. Thanks!
            And for the avoidance of doubt - most 'things' accessed through the API are 'Entities' - even the SKP model itself.
            So you can attach custom attribute keys/values in your own custom-dictionary.
            Best attached to the 'model' because 'objects' can be deleted...
            These are easy to set/get... You can also store many data types:
            boolean - e.g. true/false
            integer - e.g. 1, -2
            float - e.g. 1.2, -2.3
            string - e.g. 'cat', 'dog'
            array (of any of the above) - e.g. [1, 2, 3]
            etc...
            • AdamBA Offline
              AdamB
              Just keep in mind that if you start attaching data to every Entity, you'll have massive file bloat.
