    Dwg to SKP
    6 Posts 4 Posters 501 Views 4 Watching
      steved
      Hi Guys, I am requiring a model of a playground slide. I found one I like but only a DWG 3d model. I am not using pro at the moment (will do when money permits) Is there anyway of converting it to an SKP file?
      Thank you
      (Edited) I think there may not be a way to do it. I have attached a 3D DWG Could some kind person covert it for me ins an SKP file? It would be very much appreciated
      Thanks in advance
      Slide 3D.dwg
      "If I agreed with you on that, then we would both be wrong"
      • tridemT Offline
        tridem
        SU versions earlier than 7.1 could open dwg/dxf, you can keep both vers.7 and 8 in the same machine without problems πŸ˜‰
        • tridemT Offline
          tridem
          😞 I cannot open your file, perhaps you should save it in a 2000 or 2004 dwg version
            sketchymick
            Here you go. Cheers - Mick
            SU Slide.skp
            "I love the sound that deadlines make as they rush past"
              steved
              Thanks so much guys!
              How do I download a previous version of SU?
              Thanks again πŸ˜„
                Try this link.
