    [Plugin] LSS Matrix
    69 Posts 25 Posters 67.8k Views 25 Watching
    • gillesG Offline
      gilles
      @unclex said:
      So Many Chinese 😎
      So Many Chinese 👍
      Is this a problem for you?
      • guanjinG Offline
        guanjin
        Rotating array angle to grasp the difficulties have option positioning point of view better 😒
        Maybe I did not grasp the skills
        I come from China, is to learn
          Ok Good news for you I have find the culprit 😉
          For me in the V7 it was "SketchyPhysics"! Now groups and Component work fine! 😎
          For the V6 I must find more 😄
          • K Offline
            kirill2008
            @guanjin said:
            [attachment=1:208r8b1e]<!-- ia1 -->QQ截图20120409161643.png<!-- ia1 -->[/attachment:208r8b1e]
            Yes, plugin does not provide any helpers for array generation... but SU actually has its own built-in helpers ('Tape Measure' tool and 'Protractor' tool) so I decided not to bother on inventing my own helpers.
            Actually plugin looks for 'difference' between transformations of initial and copy instance and then applies detected difference to an initial instance. Simple as that 😄
            That's why it is necessary to pay careful attention to preprocessing stage. As a hint for more neat rotation array creation I can suggest to make an anchor point, that defines rotation center (using 'Tape Measure' tool for instance).
            Another way to make sure, that all single elements will coinside after replication, is to model the whole element, which will be rotated, then apply rotation and shift transformation to set of elements once.
            @blajnov said:
            в русском переводе не та кодировка, при нажатии на кнопку вызова основного диалога LSS Matrix. Остальные меню на русском.
            Постараюсь разобраться как можно быстрее. У меня диалог отображается корректно, пока не знаю, в чем именно может быть дело...
            [attachment=0:208r8b1e]<!-- ia0 -->русский диалог.png<!-- ia0 -->[/attachment:208r8b1e]
              How does this tool differ from my old 'Grow' and 'Matrix' tools ?
              Apart from you having to make the first changed copy...
              • K Offline
                kirill2008
                I didn't know about these two plugins 😲 (honestly).
                After brief look at 'Grow' description I found out, that 'Grow' plugin provides more functionality, than 'LSS Matrix'...
                For example, I was only going to add scaling options, 'Grow' already has exponential and even Fibonacci options aside from linear 👍 .
                As for me I was going to add a kind of adjustment curve (default option is strait line), which will give more power to affect replication results.
                Life lesson #1: search for ready made desicions before reinvent a wheel...
                  One is more "technic" the other is more ergonomic 😄 (no need to enter number)
                  • guanjinG Offline
                    guanjin
                    We look forward to the LSS update, thank you for your selfless dedication!
                      For me it's not inside the V6 Plugins folder that avoid Components to work! 😲 Maybe in Resource or other folders ❓
                      No problem because all works fine in V 7 (disable Sketchyphysics) 😉 or with groups inside V6 😉
                        blajnov
                        [attachment=0:vpwb77xn]<!-- ia0 -->русский диалог.png<!-- ia0 -->[/attachment:vpwb77xn]
                        Разобрался, преобразовал в блокноте два файла в кодировку UTF-8
                        lss_matrix.html
                        lss_matrix_mini.html
                        • K Offline
                          kirill2008
                          I think it's no good if it is necessary to disable Sketchyphysics 😞 I guess I need to find out how to coexist together with Sketchyphysics, since it is known as must have one (I don't have it personally, but I'm sure a lot of people do...)
                          BTW, Pilou, great colorful sample 👍 It inspired me to make LSS Matrix 'color aware' in future versions and process colors of replicated groups as well as transformations. I mean to make result groups colors as gradient between source group and copy group. But it will work only if the whole group has one single color, I guess... But it has to be fun too 😄
                          lss_matrix.html
                          Спасибо 👍 Архивный файл в исходном посте я заменил.
                          😄 The next in line is LSS Toolbar. It was waiting too long and I believe it's time to reanimate it...
                          • pep75P Offline
                            pep75
                            Waaawoooh!!!!!!!!
                            • EscapeArtistE Offline
                              EscapeArtist
                              What a cool tool. Thank you for sharing and your hard work!
                              • K Offline
                                kirill2008
                                You can yet use Color by Z, Color by Slope, Random Painter by Chris fullmer
                                And also ThruPaint by Fredo6 😉
                                Whoa! 😲 That's crazy cool 👍
                                Looks like it is better for me to focus on 'LSS Toolbar' update instead of bothering on colors handling within 'LSS Matrix' 😄 since there are ready-made yet powerful tools for color processing by talented plugins authors 👍
                                  It's not exactly the same than a real gradiant between the start and end 😉
                                  Only if objects are on a vertical straigth line !
                                  So you can make your own code gradient between object 😉
                                    • irwanwrI Offline
                                      irwanwr
                                      kirill, i am looking forward for your update on lss toolbar 😉
                                      • K Offline
                                        kirill2008
                                        Update of LSS Toolbar is in progress now (I'm not sure about the fact, that LSS Toolbar will be highly demanded in the nearest future, since Google sold SU and its future is a bit uncertain now, I think).
                                        Anyway here is demo video of LSS Toolbar current development stage. It shows '2 faces + path...' tool processing.
                                        [flash=560,315:5emt7pqv]http://www.youtube.com/v/2nX7ZxCPHrk?version=3&amp;hl=ru_RU[/flash:5emt7pqv]
                                        I decided to use github for version control. It is possible to download zip archive of current stage there: http://www.github.com/lssoft/lss_toolbar
                                          About the LssMatrix
                                          Does it possible to have a Cylinder at the start, and the same cylinder at the end but with only Top face scaled?
                                          http://pedagogie.ac-amiens.fr/technologie/modeleur/Devisme_TP/TP3 - Tronc de cone/Tronc de cone.jpg
                                          • guanjinG Offline
                                            guanjin
                                            Thank LSS hard work, adjustable preview, simply great, But oh have not thoroughly understand. 😄 Look forward to your updates, thank you!
                                            • 2 / 4
