    External render for client
    8 Posts 7 Posters 1.2k Views 7 Watching
    • S
      Scostumatu
      Hi all - just thought id share a render i did for a client... would like to know your thoughts
      using SU and vray + PS
      • DanielD
        Daniel
        You sure got a purty rendrin'...I likes it!
        Wondering about the paved area on the right - is it a patio? If it is, you might want to add some furniture. It seems like a lot of empty paving.
        The brick on the front facade needs to be adjusted to the right - you have vertical mortar joints on the corner (kudos for getting the coursing lined up with the window/door heads, though). You might also think about adding sills to those windows.
        My avatar is an anachronism.
        • cheddaC
          chedda
          Looks great especially the saturation and balance of colour.
          Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
          • EarthMoverE
            EarthMover
            Nice dramatic tonality to this image. Great work. Perhaps the sky could be a bit more blue and the lights a bit more yellow to push the drama factor even further. Overall...great image. Agreed with the defining of the space on the right.
            Content Creator at Skapeup
            • S
              Scostumatu
              thanks for the feedback guys - appreciated πŸ˜„
              • K
                khanhvu86
                nice render ... ^^
                • S
                  seven.sides
                  Very nice, I like the moodiness of the sky, good for contrast with the subject, makes it stand out. A few details, but others have picked them up. Nothing that jumps out though. Hope your client likes it.
                  • D
                    davidh
                    Very nice and very clean.
                    The sky might work better if it was flipped horizontally,that way you would have the dark clouds accentuated against the 2 outside lights.It would also pick up the reflected light on the right hand gable which seems to suggest the brightest part of the sky is to the right.
