    โš ๏ธ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    External render for client
    8 Posts 7 Posters 833 Views 7 Watching
      Scostumatu
      Hi all - just thought id share a render i did for a client... would like to know your thoughts
      using SU and vray + PS
      • DanielD Offline
        Daniel
        You sure got a purty rendrin'...I likes it!
        Wondering about the paved area on the right - is it a patio? If it is, you might want to add some furniture. It seems like a lot of empty paving.
        The brick on the front facade needs to be adjusted to the right - you have vertical mortar joints on the corner (kudos for getting the coursing lined up with the window/door heads, though). You might also think about adding sills to those windows.
        My avatar is an anachronism.
        • cheddaC Offline
          chedda
          Looks great especially the saturation and balance of colour.
          Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
          • EarthMoverE Offline
            EarthMover
            Nice dramatic tonality to this image. Great work. Perhaps the sky could be a bit more blue and the lights a bit more yellow to push the drama factor even further. Overall...great image. Agreed with the defining of the space on the right.
            Content Creator at Skapeup
              Scostumatu
              thanks for the feedback guys - appreciated ๐Ÿ˜„
                khanhvu86
                nice render ... ^^
                  seven.sides
                  Very nice, I like the moodiness of the sky, good for contrast with the subject, makes it stand out. A few details, but others have picked them up. Nothing that jumps out though. Hope your client likes it.
                    davidh
                    Very nice and very clean.
                    The sky might work better if it was flipped horizontally,that way you would have the dark clouds accentuated against the 2 outside lights.It would also pick up the reflected light on the right hand gable which seems to suggest the brightest part of the sky is to the right.
