    Stucco wall and alucobond materials? pls help
    renderpluginsextensions
    3 Posts 2 Posters 2.2k Views 2 Watching
      Scostumatu
      Hi all
      these are 2 materials i always try and improve. My stucco material (attached) can be controlled in the following ways.
      It has 2 diffuse layers, the main diffuse controls only the 'bump' and 'size' of the material while the diffuse1 controls the actual colour of the stucco. Be mindful that in sketchup, you will only see the bump map material displayed on your model.
      I would LOVE to know your method of creating this stucco wall material. Im happy with mine, but i know ive seen better out there. In particular nomeradonas one in this tutorial - not sure if it was photoshopped or an actual shader...
      http://sketchupvrayresources.blogspot.com.au/2011/08/making-of-flowing-tap-water.html
      ALSO, i would love to know your method of creating alucobond - see the attached image. I have also attached my shader for this but im not convinced by it. Your help would be appreciated.
      S
      STUCCO
      http://www.mediafire.com/?57dj521tm3dz629
      ALUCOBOND
      http://www.mediafire.com/?466dc2bfbcjtb68
      ALUCOBOND SAMPLE FROM GOOGLE IMAGES
        rspierenburg
        You could try this material for the metal.
        Metal Panel
          Scostumatu
          thanks so much ill give it a try
