    BoundindBox intersect problem
    12 Posts 4 Posters 785 Views 4 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      Here's my problem:
      I have to detect if 2 component instances (or their bounding boxes) of buildings intersect.
      Below is the code of the method that does it, in the class Sketchup::ComponentInstance:
      class Sketchup;;ComponentInstance
      def intersectBuildings(obj)
          return !self.bounds.intersect(obj.bounds).empty?
      The problem is that when the 2 buildings don't intersect, the method always return true instead of false, and below is an example of such a bounding box object corners:
      (76.436968m,  25399999999999994000000000000m, 0.234637m)
      (85.21837m,  25399999999999994000000000000m, 0.234637m)
      (76.436968m,  -25399999999999994000000000000m, 0.234637m)
      (85.21837m,  -25399999999999994000000000000m, 0.234637m)
      (76.436968m,  25399999999999994000000000000m, 7.018104m)
      (85.21837m,  25399999999999994000000000000m, 7.018104m)
      (76.436968m,  -25399999999999994000000000000m, 7.018104m)
      (85.21837m,  -25399999999999994000000000000m, 7.018104m)
      Y value seems to be infinite. Anyone encountered this before me ? I've not notice any answer on this subbject in this forum 😒
      Thanks in advance,
      DB
      • thomthomT
        I do think I've seen threads on the topic.
        This appear to be a similar issue:
        http://forums.sketchucation.com/viewtopic.php?f=180&t=28709
        • Didier BurD
          Didier Bur
          Thanks TT,
          I wonder why I didn't see this topic, incorrect search keywords maybe...
          DB
          • thomthomT
            I used google instead of the forum search. Often does a better job.
            • Dan RathbunD
              Dan Rathbun
              Are the building components manifold solids ??
              If so you can use my intersect_with?() method, as is:
              [ Code ] intersect_with?() Group test method
              If not, perhaps you can create two temporary manifold solids (using the bounding box vertices of the components,) then feed my intersect_with?() method, those temporary solids. After you get the boolean result, you can undo the operation (that created the temporary solids,) or just abort the operation.
              I'm not here much anymore.
              • Didier BurD
                Didier Bur
                Thanks Dan,
                The components are manifold solids.
                I'll check your intersect_with? method asap and let you know.
                DB
                • TIGT
                  You could also use this - it doesn't need manifold solids...
                  tr=Geom::Transformation.new() tgp=entities.add_group() inst=obj1.entities.intersect_with(true,tr,tgp.entities,tr,false,obj2) tgp.erase! return true if inst[0] return nil
                  You might need to mess around with the 'transformations' if the 2 objects aren't in the same context ?
                  • Dan RathbunD
                    Dan Rathbun
                    Hmmm.. the API doctionary says that entities.intersect_with() returns nil
                    Does it really return the new intersect edges ?? New faces ??
                    And if the objects are NOT in the same context.. would this method even intersect ?
                    • TIGT
                      The API is [as ever!] completely wrong - the method returns an array of all of the intersected results [edges typically, when put into a separate container as here] - just try it and see...
                      If the two intersecting objects are in different contexts you must adjust the transformations to reflect this - it can be done - I do it in 'Honeycomber'...
                      • Dan RathbunD
                        Dan Rathbun
                        IT's so crazy.. I never noticed the Entities.intersect_with() method before.
                        At first blush, it seems a strange place to have it as an instance method of the Entities collection, (being why I did not notice it,) but when you think about it.. that's the correct place for it, so that the model's context can benefit as well. (The alternative would have been to define it 3 times, in Model, Group and Component.)
                        I did notice a weird thing. If the groups do not intersect.. the temporary group is empty, and sometimes Sketchup deletes it. I did not expect this. I was trying to reuse the empty group reference for another intersect.. and got the ol' "reference to Deleted Entity" error.
                        I can see advantages to using this method rather than a boolean trim, as no undo would be needed. ( and might be faster.)
                        • TIGT
                          An empty temporary group will not survive long if you do other things, so create it just before you use it...
                          • Didier BurD
                            Didier Bur
                            Hi guys,
                            Thanks for all these comments.
                            What I'have done finally is the following:
                            • Made a hash with all my buildings and their local bounding boxes,
                            • Iterated through this hash and test all other bounding box points of other buildings,
                            • skiped all bounding boxes that are way too far to intersect with the considered building,
                            • coded a method to test if a 3dPoint is in a set of 8 points (a bounding box).
                              This is a very fast and efficient process (about 200 buildings collisions (with all 199 others) tested in 0.5 second)
                            Regards,
                            DB
