    🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Imported cad file isn´t Perpendicular to axis
    4 Posts 3 Posters 187 Views 3 Watching
    • tibetT Offline
      tibet
      hi,
      i often find, that when i import dwg/dxf file from other programs to SU,
      my 2D model isn ´t perpedecular or paralel to axes ( not sure if i explain it correctly 😄
      simply, it isn´t 100% flat, it´s slightly moved to one side ( upward or downward)
      is there any setting or plugin to fix this important odd effect ?
      thanks!
      http://i52.tinypic.com/zujcp1.jpg
      SU 2015 Pro on Win10 x64
        With any image or skp file (save as v6) difficult to imagine 😄
        Plugin Flatten vertices ?
        Or a simple Scale tool on the all selection ?
        • Wo3DanW Offline
          Wo3Dan
          @tibet said:
          ....i often find, that when i import dwg/dxf file from other programs to SU, my 2D model isn ´t perpedecular or paralel to axes ( not sure if i explain it correctly 😄
          simply, it isn´t 100% flat, it´s slightly moved to one side ( upward or downward)......
          Does your default template have slightly rotated axes?
          FAIK the imported DWG is according to the systems axes (and origin unless drawing origin preserved).
          See if resetting the axes in your template/current drawing is possible.
          • tibetT Offline
            tibet
            hi guys,
            thanks for your invaluable help.
            the original file didn't have changed axes, it happens during import between another programs too, and i can't change it any way.
            "Flatten vertices" plugin seems to solve this problem without a fuss 👍
            is there any plugin to help you to move marked face into position of another face you choose.
            good job guys !
