    Vray too slow while rendering
    renderpluginsextensions
    34 Posts 9 Posters 27.6k Views 9 Watching
      Sebasvelpa
      Hi everyone, i'm rendering an exterior scene from a small house, this must be a resolution of 4.354 * 3.508 to be printed on A3 paper size at 300 DPI, but the process takes 4 days and not finish, why? Thanks
      • soloS Offline
        solo
        Whoah!! that's 3 and a 1/2 days too long, what is your setup?
        http://www.solos-art.com
          Sebasvelpa
          Thank you for your quick answer, but I don't know how to insert an image and a file in the frum, can you help me?
            Sebasvelpa
            thanks for your quick answer, but i don't know how to send an image or the vispot file in the forum reply
              Sebasvelpa
              This is the image of the rendering process, and there is the vispot file.Thanks for the help, there is the screen print and the vispot file.
              Vispot file
              • andybotA Offline
                andybot
                you could do -4 and -6 for the irrmap min and max rates. you could also turn of antialiasing (which when it's on effectively increases you render to 6500px in order to sample 1.5 times)
                your system is also relatively underpowered in terms of processor speed.
                  Sebasvelpa
                  My notebook its a HP dv7 beats audio, core i7 2630 QM CPU 2.00 GHz 2.00 GHz, 8 GB RAM and 1 GB ATI RADEON HD 6770 M.
                    Sebasvelpa
                    Thank´s for your answer. If i need to finish in 1 day....it´s possible with the changes?
                    • andybotA Offline
                      andybot
                      sorry, I have no idea - as there are other variables, such as the type of materials (reflective and transparent materials take longer,) your lighting setup, and the complexity of your model. I would suggest rendering at 1/2 size (with irrmap set at -3 and -5) and then resampling the image to double resolution. That way you will have an image for sure. Then you can try and see if you can render the full resolution.
                      • K Offline
                        karismah
                        I'm having same problem. Scene itself is not so big. I know that curtain is killing render time, but 5 days, with no effect? Please help 😄
                        http://img266.imageshack.us/img266/9644/48425584.jpg
                        http://img20.imageshack.us/img20/2451/50326060.jpg
                        http://img213.imageshack.us/img213/3969/13994978.jpg
                        • K Offline
                          karismah
                          http://img198.imageshack.us/img198/5876/20831547.jpg
                          http://img831.imageshack.us/img831/6403/49442464.jpg
                          http://img600.imageshack.us/img600/7708/63287295.jpg
                          http://img140.imageshack.us/img140/6343/10988495.jpg
                          http://img228.imageshack.us/img228/4740/31327759.jpg
                          • andybotA Offline
                            andybot
                            What's the material of your curtain? Are you using a refraction layer? Could be the material is the culprit. Also, Do you have displacement on any of your materials?
                            Andy
                            • K Offline
                              karismah
                              I don't have refraction on curtain, I use double sided material by V-ray with translucency on bacic material and 2sided material. On few others I have bump effect but not displacement.
                              • panixiaP Offline
                                panixia
                                @Sebasvelpa: why do you have the reflect slot in the enviroment ticked? are you using the hdr+sky trick? in that case you should untick that after adjusting sun in the reflect slot..
                                • K Offline
                                  karismah
                                  Wow, I haven't noticed that! No I'm using standard sun settings. Thank you I'll try how it works off.
                                  • panixiaP Offline
                                    panixia
                                    ok, but that was not in your visopts, it was in those of the other user.. 😛
                                    • K Offline
                                      karismah
                                      I just came to office, there is a mistake in your comment. I didn't tick reflect slot in enviroment, sooo there's nothing to change 😞 But if you have any other idea plaease let me know.
                                      Thank you.
                                      • panixiaP Offline
                                        panixia
                                        no, there is a mistake in you reading my comment, because as stated (and repeated and colour-emphatized) above i was referring to the visopt of Sebasvelpa, not yours. hope you understand. 😛
                                        • panixiaP Offline
                                          panixia
                                          i don't know, the screenshot you attached are quite unreadable, moreover i don't know if there is some displacemente going on or blurry reflections etc, also i don't know which machine are you using.. your scene/geometry looks lot more complex than that of the other user.. it's hard to say..
                                          edit: i read above you are not using displacement.
                                          your scene looks utra-hi-poly however.. also maibe you are using super-heavy textures? is there refraction on the window glass? which cpu do you use?
                                          • K Offline
                                            karismah
                                            the scene has 48MB. No glass at all cause curtain is quite heavy in my opinion (double-side material). There are some blury reflection on the furnitures, mosaic wall and floor. Maybe you have nice method for great looking and not heavy curtains? 😄
                                            • 1 / 2
