    [REQ] Change GroundPlane elevation used by Shadow Settings
    3 Posts 2 Posters 725 Views 2 Watching
    • JClementsJ Offline
      JClements
      Can a Ruby be developed to allow the user to override the default ground plane so they can raise or lower it for a specific scene?
      The ground plane I am referring to would be that which the Shadow Settings dialog uses.
      • TIGT Online
        No.
        You need to move the entire model in the Z [blue], but doing that is code is probably harder than doing it by hand.
        Alternative switch that shadow option OFF and draw a [grouped] ground-plane where you want it to be...
          JClements
          Rats!
          "Alternative switch that shadow option OFF and draw a [grouped] ground-plane where you want it to be..."
          That is what I have been doing. 😞
