    LightUp v2.5a available
    extensions
    9 Posts 5 Posters 843 Views 5 Watching
    • AdamBA Offline
      AdamB
      http://i614.photobucket.com/albums/tt229/ElektraGlide/FOXScene1_2012-03-26_1842.jpg
      New version of LightUp is finished (Mac & Windows) and has a few new features:
      • Export single layer lit models to FBX file.
        This means lit models import into many (most) CAD packages with lighting.
      • Light source input accepts Kelvin and cd/m^2 forms
      • Fixes for handling Layer0 visibility
      • New "Beginner Interface" for getting started without worrying about too many controls / lighting jargon.
      • Faster lighting
        Adam
      • AdamBA Offline
        AdamB
        Here's a link to the realtime version of the scene above. It should run in your browser if you have the .luca plugin.
        http://www.light-up.co.uk/index.php?t=webplay&l=http://lightup4sketchup.com/resources/webplayer/FOX.luca
        • PixeroP Offline
          Pixero
          Thanks! πŸ‘
            More and more powerfull β˜€
            • PixeroP Offline
              Pixero
              What does "Dynamic Resolution" do?
              • AdamBA Offline
                AdamB
                Gosh you found that fast!
                So its a pretty neat new feature. Normally you set a "Resolution" at which to light your model which sets the spacing of the grid wrapped over your model. You might choose "10cm" meaning "light my model at 10cm intervals" - just as you might choose higher or lower image size in a traditional raytracer.
                "Dynamic Resolution" bases lighting grids on how much texture detail you have. It tries to map 1 texel (texture pixel) on a Face to 1 luxel (lightmap pixel) so you can produce very high quality lightmaps that can be exported using the new "Single Layer" export option.
                An example: if you have a Face with a 1024x1024 texture mapped onto it, you'll also get a 1024x1024 lightmap.
                Its a powerful option but it does mean if you have a 6000x6000 texture, you'll also get very large lightmaps... I'm looking at you Jan! πŸ˜„
                The neat thing is that you get a model that comes straight into Max,Maya,Cheetah, anything - all with baked lighting.
                Adam
                • PixeroP Offline
                  Pixero
                  He he hee! πŸ˜’
                  Acually I havent found it yet. Just read it in the whats new.
                  So where is it?
                  Single layer export might come in handy for 3d PDFs also?
                  Any plans on a direct 3d PDF export function?
                  • EarthMoverE Offline
                    EarthMover
                    Fully lightmapped 3d pdf would be amazing! I'm always amazed at how much is put into each release of LightUp given Adam is a single developer. Most big companies release a version once a year with big teams and barely add new functionally or address existing flaws. Kudos to the one man show who must never sleep!
                    Content Creator at Skapeup
                    • deaneauD Offline
                      deaneau
                      Adam, if i try to download 2.5a Fullversion) iΒ΄ll become only the downloadlink for 2.4d
                      tnx Dean
                      MADE, BORN AND LIVING IN BERLIN
                      Big Thank You to all Programmers
                      Some German words are so long that they have a perspective. M.Twain
