    LightUp v2.5a available
    extensions
    9 Posts 5 Posters 656 Views 5 Watching
    • AdamBA Offline
      AdamB
      http://i614.photobucket.com/albums/tt229/ElektraGlide/FOXScene1_2012-03-26_1842.jpg
      New version of LightUp is finished (Mac & Windows) and has a few new features:
      • Export single layer lit models to FBX file.
        This means lit models import into many (most) CAD packages with lighting.
      • Light source input accepts Kelvin and cd/m^2 forms
      • Fixes for handling Layer0 visibility
      • New "Beginner Interface" for getting started without worrying about too many controls / lighting jargon.
      • Faster lighting
        Adam
      • AdamBA Offline
        AdamB
        Here's a link to the realtime version of the scene above. It should run in your browser if you have the .luca plugin.
        LightUp for SketchUp
        Sketchup realtime lighting plugin
        LightUp for SketchUp (www.light-up.co.uk)
        • PixeroP Offline
          Pixero
          Thanks! πŸ‘
            More and more powerfull β˜€
            • PixeroP Offline
              Pixero
              What does "Dynamic Resolution" do?
              • AdamBA Offline
                AdamB
                Gosh you found that fast!
                So its a pretty neat new feature. Normally you set a "Resolution" at which to light your model which sets the spacing of the grid wrapped over your model. You might choose "10cm" meaning "light my model at 10cm intervals" - just as you might choose higher or lower image size in a traditional raytracer.
                "Dynamic Resolution" bases lighting grids on how much texture detail you have. It tries to map 1 texel (texture pixel) on a Face to 1 luxel (lightmap pixel) so you can produce very high quality lightmaps that can be exported using the new "Single Layer" export option.
                An example: if you have a Face with a 1024x1024 texture mapped onto it, you'll also get a 1024x1024 lightmap.
                Its a powerful option but it does mean if you have a 6000x6000 texture, you'll also get very large lightmaps... I'm looking at you Jan! πŸ˜„
                The neat thing is that you get a model that comes straight into Max,Maya,Cheetah, anything - all with baked lighting.
                Adam
                • PixeroP Offline
                  Pixero
                  He he hee! πŸ˜’
                  Acually I havent found it yet. Just read it in the whats new.
                  So where is it?
                  Single layer export might come in handy for 3d PDFs also?
                  Any plans on a direct 3d PDF export function?
                  • EarthMoverE Offline
                    EarthMover
                    Fully lightmapped 3d pdf would be amazing! I'm always amazed at how much is put into each release of LightUp given Adam is a single developer. Most big companies release a version once a year with big teams and barely add new functionally or address existing flaws. Kudos to the one man show who must never sleep!
                    Content Creator at Skapeup
                    • deaneauD Offline
                      deaneau
                      Adam, if i try to download 2.5a Fullversion) iΒ΄ll become only the downloadlink for 2.4d
                      tnx Dean
