    Solids from an imported dxf
    3 Posts 2 Posters 209 Views 2 Watching
      srawcliffe
      Dunno if this is a newbie topic, but I'm certainly a newbie, so here goes ...
      I've succeeded in importing a dxf file (thanks to FreeDXF!) but can't see how to transform the collection of lines into surfaces on which I can use Push/Pull.
      The drawing is of a (French) power outlet, and I need to pull up the fascia, push in the central cavity, and pull up the earth pin, to create a 3D model.
      I'll be needing to do the same things on a few similar files (switches, etc.) so need to know how this works.
      Am attaching the Sketchup file and the original dxf.
      Using Sketchup 8 free.
      Be very grateful for any help!
      Regards,
      Steve
      The original
      The file as imported
      • dukejazzD Offline
        dukejazz
        Explode 2 times or bomb (some time you need to explode more than once)
        Then use make face tool or draw a hroz line one side to other side to make faces
        push-pull for hight: This jpg is just showing that I push pull it.
          srawcliffe
          Dukejazz,
          Thanks for that.
          I did draft a post saying I'd solved the problem, but I must have forgotten to hit "submit" πŸ˜’
          For anyone else with the same requirements, here's the procedure that worked for me:
          • Download Make Faces from here: http://www.smustard.com/script/MakeFaces and install
          • Explode the drawing twice (like you say)
          • DON'T group the exploded lines to form shapes (tried that, and it prevented the next step from working)
          • Use Tools>Make Faces to create faces from the spaces bounded by the lines
          • Push/pull as usual
          So I'm a happy bunny
          Steve
