    Odd shape "slice"
    8 Posts 5 Posters 438 Views 5 Watching
    • G Offline
      grapefruitsketch
      Another newbie problem - since you were so good with the skateboard - here's another thing.
      Image draft attached, don't laugh, it's like 5 years old had drawn it. But the problem is, this is a corner element, the first image on left is the side view. Two of these components are place to 90° angle at each other (top view in the middle), but the corners are not touching. The top part is curved. Then there is the front face, which is my problem, it's linear in side view but horisontally curved at top (the yellow part). How do I get this surface done?
      I hope you understand what I'm trying to do.
      • mitcorbM Offline
        mitcorb
        To my eye, the top view does not seem to coincide with the "3d view" you provide, unless the view is dead on parallel with the short side of the figure.
        • G Offline
          grapefruitsketch
          Yeap, as said, it was badly drawn and the cut corner doesn't really show in the "3D". Here's a .skp file of that, my problem is I can close the straight part of that (done in .skp), but not the curved top. Anybody for help?
          slices.skp
            Skinned with curviloft (search for it under the plugins index)
            slices.skp
            • gillesG Offline
              gilles
              Standard tools
              #1 draw the two profiles
              #2 extrude with PushPull
              #3 select all, right-click/intersect with selection
              #4 erase unwanted geometries.
                sketchymick
                I don't think I fully understand the shape you're trying to create, but I had a go at something similar anyway. Maybe this will help? Cheers - Mick
                corner.skp
                "I love the sound that deadlines make as they rush past"
                  Yes, if I had to start from scratch, I would also go for some similarly simple solution. 👍
                  • G Offline
                    grapefruitsketch
                    Thanks a million all! Love you!
