    Angaston pavilion
    36 Posts 20 Posters 4.0k Views 20 Watching
    • massimoM Offline
      massimo Moderator
      Thank you. πŸ˜„
        archkeenidea
        nice style , love it πŸ‘
        • eidam655E Offline
          eidam655
          looks nice πŸ˜„ so the grass is only a rectangle with an alpha texture and copied all over the place?
          I'm using SketchUp 2017, V-Ray 3.4
            Roger
            Where can I learn the work flow involved in the instancing? Is that one 3D plant" Are any of the parameters of the plant randomized in each instance? Is the placement of the plants done on SU or in Thea?
            http://www.azcreative.com
            • massimoM Offline
              massimo Moderator
              Thanks guys. πŸ˜„
              No it's 3d. Haven't modeled it myself though.
              In Thea of course, all that 3d vegetation would easily kill SU.
              Actually it is quite simple: it's almost like Kerkythea but of course more powerful. You have to input a canvas (a portion of the terrain defined by a material) and an instance (the model of the grass or of a tree) and then you can use a "populate" command or a "brush" tool. Each tool is customizable.
              I've used four different instances for the grass and two for the trees. Anyway you can assign to each package of instance+canvas (and that will affect randomly each generated instance) parameters such as Direction, Normal, Roll, Scale (percentages), Minimum distance (meters) etc.
                Roger
                Am I correct that THEA runs as a SU plugin and as a plugin costs about $60?
                  No, Thea is a standalone studio renderer that sells for € 295 (application + two nodes) and the exporter plugins are sold separately - the SU plugin for € 39.5 (that would be around $ 52-53) plus tax where applicable.
                  See the whole pricing table here (for me at least, prices appear in €):
                  http://www.thearender.com/cms/index.php?page=shop.browse&category_id=1&vmcchk=1&option=com_virtuemart&Itemid=53
                  • massimoM Offline
                    massimo Moderator
                    A close up from the terrasse. πŸ˜„
                    Here I've used a double panel glass.
                    • majidM Offline
                      majid
                      this is really great, mate. I love the simplisity and light mood. πŸ‘
                      • massimoM Offline
                        massimo Moderator
                        Thanks Majid. πŸ˜„
                        • wychylylybymyW Offline
                          wychylylybymy
                          thea is aweasome, I love Proxy model, but on the last view your sky looks fake.
                          qb.carbonmade.com
                          https://www.facebook.com/qbwizualizacje
                            Roger
                            Dear unpronounceable, to me, the sky looks very realistic. My impression is the bottom of a storm cloud overhead with the sun hitting the building in the last moment of sunset.
                            • massimoM Offline
                              massimo Moderator
                              Yeah, Roger is right. The sky is a spherical HDR photo of a sunset sky used as background+lighting. You can find it here. Here is a miniature.πŸ˜‰
                              • RichardR Offline
                                Richard
                                Stunning work Massimo! Mate can you place your proxies in SU and export to render without need to open in Thea?
                                BUILTBRAND.COM.AU
                                • massimoM Offline
                                  massimo Moderator
                                  Thanks Richard really appreciated. πŸ˜„
                                  As far as I know you can export components as proxies and then in Thea you'll have a single component. You can do some changes to all the proxies at once, e.g. subdivision of the mesh, some changes on the geometry, assignment of materials etc., but actually you can't replace the proxies with other models in your HD during the render even if I think it's in the roadmap.
                                  Instead for instancing you have to load a model in Thea and then use it on a canvas as I explained in a previous post.
                                  Hope I've understood what you meant. πŸ˜„
                                  • RichardR Offline
                                    Richard
                                    Cheers Massimo.
                                    Can't wait to see your interior shots. BTW I reckon you need to get rid of the fence on the left side of the building.
                                    BUILTBRAND.COM.AU
                                    • 2 / 2
