    Indigo Exteriors
    11 Posts 5 Posters 2.0k Views 5 Watching
    • W Offline
      Whaat
      Hey all,
      Here are a couple of recent projects. Grass is added in post. All other plants are 3D, mostly external OBJ references that are substituted for a proxy at render time.
      Hi-res version here:
      http://dl.dropbox.com/u/22333105/DecoraHomes/Final/Vdara_r1.jpg
      • P Offline
        pibuz
        Hi Dale! The nighttime render is very good!
        ..I think both images lack a little more depth in the frontal part, maybe a longer shadow of a tree, or a car in front of the garage would have helped..
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
          Cherryni
          Very nice house render. I like the daytime one better.
          • W Offline
            Whaat
            Thank you for the comments. Here is a dusk shot just finished.
              bolkop
              Very nice renders... do you use Photoshop for adding the grass? How can I make the transparent space between the stems of grass at the edge of lawn. Can you recommend any good tutorial?
              • W Offline
                Whaat
                Thank you!
                Up until now, I have used Photoshop for the grass. There is a grass brush in Photoshop that I use to paint along the edges of the lawn. This gives the space between the stems. The brush is applied to the grass layer mask. The grass itself is just a photograph.
                I have just started using 3D grass because I was finally able to get the results I wanted. I use the excellent MakeFur plugin to scatter the grass 'proxies' across the lawn. Smaller but denser grass clumps are used along the borders of the lawn. I use at least two different colors of grass clumps to add color variation.
                3D grass
                grass proxies (lines) and sample grass clumps
                • P Offline
                  pibuz
                  Your 3D grass is excellent Dale! Mind to share how you did that/the base component?
                  • W Offline
                    Whaat
                    Thanks Pibuz, it took a lot of trial and error.
                    See image for my Grass fur preset settings. I make two color variations of this component (three might even be better). I also create a very small (1"x1") clump that gets scattered along the borders with greater density.
                    I use the MakeCrowd feature of MakeFur to scatter the proxies over the base mesh and I use Fredo's Offset Surface tool (from Tools on Surface) to create the border surface.
                    • P Offline
                      pibuz
                      Thank you!! ..that grass is wonderful.. I HAVE to reproduce it πŸ˜†
                        ccs1987
                        i am just recently playing with making fur plugin and had been doing a lot of research recently to make it denser. i am glad i found ur pic and your scene rendered is amazing and it's the effect that i am looking for. But i am quite blur with ur description. Do you have some pictorial tutorial instead?
                        Sketchup 8 pro
                        Vray
                        Intel Xeon W3520 2.67Ghz
                        12Gb Ram
                        Nvdia Quadro FX 1800
                        • W Offline
                          Whaat
                          There is some more info here: http://www.indigorenderer.com/forum/viewtopic.php?f=19&t=11521
                          The technique is somewhat specific to Indigo Renderer
