    [REQ] Component 'Name' Stripper
    11 Posts 3 Posters 709 Views 3 Watching
    • bmikeB Offline
      bmike
      Looking for a plugin that strips components of their 'Names'.
      These names can often be the same (when the definition is unique), and when working with other people's files I often have to clean up before I export to various materials lists.
      I tried TT Cleanup - but it didn't change anything.
      I ended up opening the drawing on my old laptop and was able to window all components and do a space bar / delete in the 'Name' field in the entity information window. Oddly, this works on PC, but doesn't seem to work on Mac...
      mike beganyi design + consulting llc
      • sdmitchS Offline
        sdmitch
        bmike, no plugin needed just a single statement entered in the Ruby Console will do the trick.
        Sketchup.active_model.entities.each{|e| e.name='' if e.is_a?(Sketchup;;ComponentInstance)}
        Will remove any Name assigned to a component instance. The Definition Name can be changed but not erased.
        http://sdmitch.blogspot.com/
        • bmikeB Offline
          bmike
          Thanks, will give it a go!
          I don't want to mess with the definition name - but I get into trouble when someone sends me a drawing with 100 'Posts' in it, an 80 of them are different from each other. Exports out to materials lists wrong.
          Is there a way to 'plugin'ize this so that I can pull it down from a menu, as opposed to keeping a bit of text handy?
          • sdmitchS Offline
            sdmitch
            Copy this code and paste into a pure text editor program,ie Notepad, and save
            it to the Sketchup Plugins folder. Execute it by choosing Name Stripper from
            the plugins menu.
            require 'Sketchup'
            if not file_loaded?(File.basename(__FILE__))
              UI.menu('Plugins').add_item('Name Stripper') { Component_Name_Stripper.doit }
              file_loaded(File.basename(__FILE__))
            module Component_Name_Stripper
              def self.doit
            • bmikeB Offline
              bmike
              Thank you!
              I'll give it a go. Was just thinking about taking apart another .rb so I could tinker with it.
              • bmikeB Offline
                bmike
                Did that, and this is what I get:
                Error Loading File namestripper.rb
                undefined method ` ' for main;Object
                  Looks like you have a ` rather than a ' somewhere in the code 😕
                  You must use a plain-text editor - like Notepad.exe.
                  It can't be a wordprocessor because that will/could 'format' text breaking the tight syntax required by Ruby...
                  Simple select all of the code and copy its text from the code-pane and paste into the empty file...
                  • bmikeB Offline
                    bmike
                    Hmm. Pasted it into TextEdit on the Mac. Will try something else.
                      Here's the code in a .rb - compare it with yours...
                      Test both in turn in the Plugins folder, with a restart...
                      namestripper.rb
                      • bmikeB Offline
                        bmike
                        Thanks Tig!
                        Here's what I get when I pated them both into TextEdit on the Mac:
                        TIG;
                        require 'Sketchup'
                            def self.doit
                        Original;
                        require 'Sketchup'
                          def self.doit
                        • bmikeB Offline
                          bmike
                          Your copy is working fine directly placed in my Plugins folder... so, Thanks!
