    Vray grass tutorial - help
    5 Posts 4 Posters 11.7k Views 4 Watching
    • P
      packanik
      http://forum.rhino3d.pl/index.php?PHPSESSID=d383e73bba4f10a199c6f049ec08a4cb&action=dlattach;topic=444.0;attach=6130;image
      http://forum.rhino3d.pl/index.php/topic,444.0.html
      This is an old tutorial vray for rhino (in Polish)
      Is it possible to obtain the same results for vray for sketchup?
      translation - google translator
      Regards
      I found the same tutorial in vray for sketchup
      http://www.youtube.com/watch?v=s9M2U7CTXGg
      only that I have versions of "VRayForSketchUp-1.49.01"
      Such are the results
      rotation - 9
      http://packanik.website.pl/grama1.jpg
      rotation - 1
      http://packanik.website.pl/grama 2.jpg
      please help
      • P
        pololo
        I have this same problem with vray 1.49.01 !! 😒
        Any suggestion?
        • DVERGERD
          DVERGER
          This technique works with 1.05 not with 1.49, and it's a pity... 😞
          • eidam655E
            eidam655
            i guess i must have tried it last time with 1.48 and forgot about it in the new version.
            i had no success with clicking around in 1.49 either.
            I'm using SketchUp 2017, V-Ray 3.4
            • eidam655E
              eidam655
              thanks for the link, i was searching for this texture for so long! 😄
              anyway, i would try to apply the texture to a V-Ray infinite plane, and not just a regular rectangle, as is seen in your image.
              EDIT: also you should follow the tip in this post (as the Texture/Environment options got rolled into one dropdown menu)
