    Can Sketchup Ruby find the path of a SKM file?
    5 Posts 4 Posters 748 Views 4 Watching
    • dereiD Offline
      derei
      Is it possible to find the path of a Skm file loaded from a library ?
      I know there are methods to work with material that are in model, but if I load a material from a library, is any way to retrieve the path where that material rests on my hard-drive?
      DESIGNER AND ARTIST DEREI.UK
      • Dan RathbunD Offline
        Dan Rathbun
        material.texture.filename ??
        And TIG has his SKM Tools available in the Plugins forum (check the index.)
        I'm not here much anymore.
        • dereiD Offline
          derei
          As this code looks like, I'm sure it returns the filename of the texture INSIDE the SKM. I'm interested to retrieve the path where my SKM is saved on hard-drive, like C:\Program Files\Google\Google SketchUp 8\Materials\Groundcover\Groundcover_BarkChips.skm
            No SKM features is exposed to the API.
              As said... there are currently no access to SKMs in the API [only materials and textures], but my SKMtools do add extra methods to allow you to import a SKM file as anew material, export a material as a SKM file, and do several other things - like extract a SKM's image and thumbnail etc...
              Search the Plugins Index and get it...
