    Script to bring all components from library into SU model
    6 Posts 3 Posters 441 Views 3 Watching
      samyell77
      I started this post in the Sketchup forum but wonder now whether it might be better in here.
      Wonder if anyone can help me to find or write a script that will allow me to bring all of the components from a component library into an SU file. Ideally I'd like to be able to place them next to each other in a line or on a grid (say 1000mm grid).
      Is this possible to do? Currently Im having to manually load components and would like to find a quicker way to do it.
      Sam
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
        samyell77
        Ive been having another trawl around to see if I can find away to do this and found this post which seems like the perfect starting point.
        http://sketchupapi.blogspot.com/2008/03/inserting-external-sketchup-component.html
        This is the script I have been trying to get to run
        pants_def = Sketchup.active_model.definitions.load("C:\pants.skp")
        Sketchup.active_model.place_component(pants_def)
        I have changed the file path to match where I have saved the file on my computer but I keep getting the following error message if I run the script.
        (eval):2537
        pants_def = Sketchup.active_model.definitions.load("C:\Users\sam.morris\Desktop\pants.skp")
        Error: #<IOError: (eval):2537:in `load': Invalid component file>
        (eval):2537
        (eval):2537
        Apologies for the probably being a complete noobie error on my part but Im trying to work out how to do this.
        I have downloaded the two components from the post and have changed the name of the skpfile to pants to match the script. I know this post is very old (2008) and I wonder if it may be that the way ruby works has changed since then but Im stumped. It seems like a very simple code and I feel like a simpleton for not being able to get it to work.
        Any advice much appreciated.
        Sam
        SU Pro 2016
        PC Windows 10
        16gb RAM
          If you use \ as the file separators in filepaths you must either enclose the path inside '...' OR 'escape' the \ if it's inside "...", alternatively use /, inside either '...' or "...'
          So - assuming the file does indeed exist - these are valid...
          pants_def = Sketchup.active_model.definitions.load("C:\\Users\\sam.morris\\Desktop\\pants.skp") pants_def = Sketchup.active_model.definitions.load('C:\Users\sam.morris\Desktop\pants.skp') pants_def = Sketchup.active_model.definitions.load("C:/Users/sam.morris/Desktop/pants.skp") pants_def = Sketchup.active_model.definitions.load('C:/Users/sam.morris/Desktop/pants.skp')
          BUT this is NOT valid...
          because of the non-escaped '' inside "..." subtly changes the meaning and it's therefore no longer a valid path when Ruby reads it !
          If you are copying filepaths from 'Windows' folders etc use them inside '...' or if used inside "..." then remember to edit the text to double up every \ as a \ ...
          Inside "..." a single \ is a special character that gives the character that follows it a different meaning.
          So "\n" is a new-line and "\t" is a tab etc.
          So to make Ruby see a \ that is inside "..." as not this special character, but as a real , you must double it up thus "\\" πŸ€“
          • dukejazzD Offline
            dukejazz
            Open two shetchup: Copy and paste to another shetchup and lay them out so you can see your object: if you see what want then copy back
              samyell77
              Thanks dukejazz - but it still means I have to load all of the component from the component browser in the first place. I have hundreds (around 700 at last count) of components to load so am trying to find a way to load them all 'automatically' with the use of a script. I don't currently have them all in one file to copy from, they are all saved as individual components in a component library folder.
              SU Pro 2016
              PC Windows 10
              16gb RAM
                samyell77
                TIG - thanks for the thorough explanation. Still coming up against some problems with the next part of the scrip but will do some further reading when I get time to see where Im going wrong. Totally new to scripting so need to try to get my head round this a bit better.
                Cheers πŸ‘
                SU Pro 2016
                PC Windows 10
                16gb RAM
