    Help needed with organic modelling
    Scheduled Pinned Locked Moved Organic Modelling
    31 Posts 9 Posters 21.9k Views 9 Watching
    • O
      o0rico0o
      ok thats great, im trying that now. I've intersected the overall form manually then grouped the shape and left the intersection lines which i then welded. When I apply the component stringer the components are scattered randomly due to the geometry of the line, is there any way to smooth the line and then divide it into equal lengths of geometry so that the components get scattered equally?
      • HieruH
        Hieru
        I've only used the plugin for basic stuff so I'm not sure. I'll have a look when I'm back in the office tomorrow.
        www.davidhier.co.uk
        • O
          o0rico0o
          great stuff, thanks alot
          • R
            rspierenburg
            I'm not sure what your intended final output of this model is, but could you just use texturing for the windows. I'm just thinking with the number of components you need for windows its going to make the model hard to work with.
            • O
              o0rico0o
              I did think about texturing, but i will be later using the model to generate floorplans, elevations and sections so really need all of the geometry to be there and to be accurate.
              • HieruH
                Hieru
                The only suggestion I can come up with is redrawing each floor profile with a set number of evenly sized segments. You should then be able to do something like this:
                StringerWindows.skp
                www.davidhier.co.uk
                • L
                  ledisnomad
                  This might not be the best answer, since we are on SketchUcation and all, but have you considered another software package? What you are doing would be much easier in Rhino with Grasshopper, Revit, Bentley GC, or something like that. You could always create the mass and populate it with windows, then bring it back into SketchUp for your other drawings and adding other stuff.
                  • DareDevilD
                    DareDevil
                    Bad idea... If you want a total architectural model, you have to use an architectural CAD or BIM tool. Sketchup is not. SU is a geometrical modeler, so you can imagine use it for elevations but not for complete sections or floorplans in this kind of complex project... Ok, you can do it, but it's not the easiest tool and not the most flexible, as you can make an total architectural model sculpting in a bloc of wood but is better make it with cardboard.
                    So, my opinion, use SU to make the external model with floors (and with this kind of shape, you better use a NURBS tool like free 123D), use it for elevations, and extract sections and plans and draw all details in a 2D CAD if you don't want to use BIM tool.
                    • masterpaulM
                      masterpaul
                      I found this thread to be a really usefull tutorial.
                      • O
                        o0rico0o
                        Hi Guys, just a little update/ cry for help....
                        I'm Just working on the facade for this tower in particular the little slats and window details. In doing this I've just realised that I've made a rookie error. I forgot to orient all the faces so that they will render correctly, theres are so many individualfaces that selecting them all or even using front face tool and rolling the mouse over them all will take too long. Is there a plugin that will allow me to select all the faces and then select an face as a basis to orient all the faces in the same direction? heres a little screen dump of what im working with....Screen Shot 2012-04-24 at 19.43.43.png
                          No problem if all that is copy of components ?
                          Just edit one instance or a little more complex
                          Create a new component, select all goto the Components Menu / In Model
                          RightClick on the icone of the new Component: Replace Selected
                          If all that is copy of groups Thomthom plug Selection Toy can save you!
                          Convert into Components - Converts all the group copies into components. Transformation and materials will be transferred.
                          Useful for when you have a model where groups where used instead of components.
                          So you will can modify one component as above ๐Ÿ˜‰
                          If not that is another "rookie error" ๐Ÿ˜„
                          If all that is not components or groups
                          if you are very lucky maybe right click on a white face / Oriente faces do the trick in one time
                          That will say that you have made a curious modeling ๐Ÿ˜‰
                          (but I doubt)
                          In last chance Fredo 6 has made a plugin Reverse orient face who can maybe help you
                          in a hand workflow
                          At the end maybe some TIG plug can make something like fix reverse side Material ?
                          If all that don't make the trick, your last chance is a persannal plug cooks by TIG with
                          maybe a special selection of a similar face ?
                          Bu we must wait more details of the situation ๐Ÿ˜„
                          or maybe a file skp
                          • 2 / 2
