    Wrap design around surface ? i´m stuck
    3 Posts 2 Posters 348 Views 2 Watching
    • tibetT Offline
      tibet
      hi,
      i wonder how many techniques are available, when i need to wrap face around non-flat surface/faceeg. a mug?
      i usually import dxf file,then make face (make faces 1.4) and try to stick to the surface of an object.
      i know just projection or intersect faces techniques ( design is often much larger/longer than sample below )
      is there any other faster way to eg around an object( even non flat and bumpy surface ) please?
      thanks for your valuable tips !
      http://i.imgur.com/plQPD.jpg
      http://img.acianetmedia.com/i/fZatR.jpg
      just a couple of thoughts here.
      there is another harder question, how to put graphic to a outer ball, then to project to inner ball.
      http://i52.tinypic.com/zujcp1.jpg
      SU 2015 Pro on Win10 x64
        driven
        I had fun with this a while back, not sure if it works in v8, or maybe TIG's 'super glue'[ can't remember name...] john
        http://forums.sketchucation.com/viewtopic.php?f=323&t=24676&start=15#p212945
        • tibetT Offline
          tibet
          hi driven,
          thanks for your tip, it´s a cool plugin !
          it looks great , but videos doesn´t work.
          i contacted kirill2008, hope to get some good news soon 😄
          cheers !
