    Layering SU references
    layout
    13 Posts 5 Posters 1.6k Views 5 Watching
      sonder
      I've been playing with the advantages and disadvantages of both Vector and Raster rendering. It is always a compromise of graphic/visual quality vs. graphic/visual accuracy vs. render time.
      While playing around, I realized you can layer SU references over eachother and designate one to be raster render and one to be vector render. One very cool aspect of the SU section tool is that it allows you to create a group from the actual section cut. It not only creates a group, but a component within the group. This is really cool as you can open the group, then copy the component out of the model to edit. You can then set the line work of the specific component along with assigning color or tone to the faces created in the section.
      Here is the big workflow advantage. While vector rendering takes forever on an entire model, it is extremely fast on isolated line work - such as a section. So you can have a base reference that is raster rendered - such as a floor plan or reflected ceiling plan or section. Then you overlay at the same scale a SU reference that is only the isolated component/group created from the section cut and set it to vector render. You can then easily set it over the raster image to create an amazing plan or section.
      Doing this also helps for dimensioning as you can assign the vector portion to an isolated layer allowing for more precise selection.
      • utilerU Offline
        utiler
        That's exactly what I do too, Sonder. I only ever use Vector and Raster and layer references to get the required solution.
        Nice work too!! πŸ‘
        Just Curious...
          sonder
          Thanks. It was definitely eye opening for me. I never have the issues with waiting for a render anymore. Heck the line work in vector renders faster than the whole model refernce in raster. I am almost done with 3 full CD sets done in Layout. Now that I finally have the system half way dialed, I am faster than I was with ACAD (I learned ACAD on version 2.0 and used it daily until last year).
          • utilerU Offline
            utiler
            I just hope that Google see the importance of extending LO's capabilities in the next release which allows LO and SU to work more efficiently with regards to this particular part of the process.....
            Just Curious...
            • pbacotP Offline
              Andrew and Sonder,
              Could you show a small detail sample of what it is you are doing with vector linework? Is it just that the lines for a section wall outline is crisp compared to the rest of the drawing, or....? The image you posted isn't big enough to show the output quality.
              Thanks, Peter
                ArCAD-UK
                I can see the benefit of being able to give LO a simple reference for dimensioning with just the section lines, but I don't see how this is better than a hybrid section and switching between scenes e.g. with & without background?
                Isn't there a risk that you will have to do a lot of redrawing to the exploded section if there are significant (client) changes to the building?
                Really like your drawing style Sonder.
                • pbacotP Offline
                  I think it's for faster rendering than hybrid.
                  Why not dimension the raster in any case?
                  It's exploded?
                    sonder
                    Sorry - do not explode the line work. Leave it as a reference set to vector. Otherwise, you lose the tie to the original model.
                    The advantage with dimensioning, is the simplicity of the section cut, whether it is a vertical section or horizontal plan. My models are detailed with baseboard, trim etc. Sometimes you have to be careful you do not hit the edge of a piec of 3/4" trim. Since the section for a plan is cut above the floor, it does not show the trim in the line work, making dimensioning must faster.
                    Yes the vector line work is crisp lines, while the model can show all the materials/shadows etc. The advantage of this method is primarily work flow. LO renders the basic line work nearly instantly in vector mode. The model rendered in raster is also very quick. Both Hybrid and vector rendering of the entire model is far too slow. If your output quaility is set to high, 1/4" scale plans read beautifully. IMHO, graphically it is far superior to hybrid or vector only rendering.
                      sonder
                      Here is a reflected ceiling plan I am working on. I enlarged an area so hopefully it shows what I am referring to a little better.
                      • pbacotP Offline
                        Thanks, Sonder. So I think I see the walls are vector right? And in a print they'd be crisp. You shade the ceiling somehow with the sun from below as if you cut the house in half and flipped it over? 😲
                          sonder
                          Yes the walls are vector. I actually struggled at first on how to do a true reflected ceiling plan. What I do is have a second SU model which the original model is referenced. I then mirror the model about the Z axis, cut a horizontal section and the result is a true reflected ceiling plan. Since it is mirrored about the Z axis, you still get the cast shadows which I think really helps with depth.
                            caronte01
                            Hi Sonder,
                            Could you show us a screeshot of your layout layers, and of your model scenes? While in principle it seems as a good idea, I would imagine it has to be a very complicated setup. Correct me if I'm wrong.
                            Anyway, great work. I keep going to your posts for inspiration!
                            Cheers
                            s
                              sonder
                              Thanks!
                              It is not complicated at all. My layer setup is very simple:
                              The Section line work reference goes on a layer I name RCP linework (modify for type of drawing)
                              SU reference goes on a layer named SU Reference
                              The grids are on a layer called grids
                              The notation is all on one layer called notation.
                              You can add more as needed, but isolating these individual layers is what you see on the RCP above. You then position the layers in order of visibilty and lock as needed. I typically keep all reference layers locked and only unlock to update.
                              As for model scenes, they are just each section or plan view saved as a separate scene. For plans that require many sections, I will typically create a separate SU file and reference in the base model. This way you don't end up with 15 section planes in a given model.
                              So far so good on this method. Rendering time is pretty much instant for both the raster and vector linework. I have used this method now for all my plans, reflected ceiling plans and building sections. It works great!
