    [Plugins] TIG-splitTOOLS
    50 Posts 17 Posters 80.2k Views 17 Watching
    • TIGT
      Here's v2.0
      The three 'Split' tools are now included in this tool's RBZ. They are signed for v2016.
      404 Not Found
      (sketchucation.com)
      There is no need to install the separate Split tools.
      These will no longer be available from the PluginStore individually...
      • J
        johnnygitarr
        hi TIG,
        thank you for the split tool plugin. its very usefull.
        can you uprade the tool for also splitting triangles in quadfaces?
        (draw a line perpendicular from each side of the triangle to the midpoint
        of the triangle = then you have a quadface triangle).
        greetings
        johnny
        • TIGT
          There is a tool already,,,
          https://sketchucation.com/pluginstore?pln=Quadrilateralizer
          If there's more than one connected face, then you need to do the following steps...
          If you select the required face, then make it into a group, edit that group, then next run the tool on the freshly selected face - if desired you can exit the edit and explode the temporary group...
          Edit: This recent extension might also be of interest...
          https://sketchucation.com/pluginstore?pln=SB_Trilateration
          • C
            CesPv
            Where can I download the others split tools?? I can use anything because I don't have SplitUp, SplitDonut and SplitSausage.. Help!!
            • TIGT
              Three posts back I posted a link 3 years ago !
              https://sketchucation.com/forums/viewtopic.php?p=601903#p601903
              • designerbursaD
                designerbursa
                Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TIG-splitsausage.rb:85:in add' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TIG-splitsausage.rb:85:in splitsausage'
                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TIG-splitTOOLS.rb:93:in `block in splitTOOLS'
                • TIGT
                  Your error report does not have any useful context info.
                  Please explain what you have selected and are trying to do...
                  • O
                    ovaleks
                    Hello TIG, thank you. Can we divide a randomly drawn or trapezoidal surface into a number of equal areas? Thank you.
                    • O
                      ovaleks
                      • O
                        ovaleks
                        • 3 / 3
