    Rendering on parallel proyection with vray
    renderpluginsextensions
    4 Posts 4 Posters 16.6k Views 4 Watching
    • N
      N3MES1S
      Hi guys, i am a bit desperate. I am trying to render a parallel proyection with vray, with the physical camera off, but i cant get it to work.
      The main problem is that for no reason, its like vray ignore any camera distance setup and just make the render in front of the object, like a zoom, and i only can see 30% of the object.
      I dunno wat im doing wrong, i have the camera physical disabled, and i only using the GI color and the sunlight at 0,2 intensity.
      Any ideas?
      • chonC
        chon
        VRay can't render parallel projections.
        So, best way, set the zoom tool on the lower angular field as possible (1Β°) to simulate the parallel mode. πŸ˜‰
        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
        • B
          bhbarchitects
          nomerdona has a great hack
          set the field of view to 1, select the face you want to be parallel, right click and align view.
          Renders great
          • N
            nomeradona
            Here is the trick// http://www.sketchupvrayresources.blogspot.com/2012/02/tutorial-2-point-perspective-rendering.html
            visit my blog: http://www.nomeradona.blogspot.com
