    Locating Original Projection Plane
    5 Posts 2 Posters 433 Views 2 Watching
    • P Offline
      pmolsen
      When I project a texture onto a curved surface I always retain the original plane that I used to project from, either on a hidden layer or in a separate file, to allow for future manipulation if needed.
      If I lose the original plane, is there any plugin that will allow the calculation of the position of the plane, such that I can re-create it so as to be able to adjust the texture slightly?
      If not is it feasible to write such a plugin? The necessary information must exist somewhere since if you re-project the texture onto a new surface that is parallel with the original plane, the "Texture/Position" option is not greyed out, whereas it is greyed out if you project it onto any other surface and try to reposition the texture.
      • PixeroP Offline
        Pixero
        Not exactly the same, but I have written a plugin that does planar UV projections in x, y, and z axis.
        http://forums.sketchucation.com/viewtopic.php?f=323&t=34552
        • P Offline
          pmolsen
          Would it allow the original plane to be determined and recreated?
          • PixeroP Offline
            Pixero
            No. It's just for projecting new textures along each x, y, or z axis.
            • P Offline
              pmolsen
              I imagine that the plugin would determine the normal to the projected texture, from which one could construct the plane.
