    Push-Pull Along Normal
    4 Posts 3 Posters 443 Views 3 Watching
      RoodyJ
      I've tried both Didier's and the SCF Power Toolbar push-pull along a normal to surface plug-in. They work for integer values of distance. However, when I enter anything other than an inter, I receive an error. Am I doing something incorrectly, or do I have a configuration issue?
      Distance entry for non-integer value
      Error for non-integer values
      Thanks for any help you can provide.
      Jim
      • massimoM Offline
        massimo Moderator
        I don't know which plugin you are using and I don't have the the SCF Power Toolbar, but both "push-pull faces along vector" and "push-pull faces along their normals" included in Didier's projections plugin work fine with non-integer values.
        • mitcorbM Offline
          mitcorb
          Fredo6's Joint PushPull has also by Normal and by Vector. Could this be of any help?
            RoodyJ
            Thank you both for your input. The Projections plug-in is still screwy, but I am using Fredo's and it works fine.
            Again, Thanks for helping.
            Jim 😄
