    Counting DC Sub-Components
    1 Posts 1 Posters 366 Views 1 Watching
      rward
      Hello All, is there a function i can use in the attributes to display the count of all instances of a copied Sub-Component?
      I create a rectangular array, and then delete & rotate some of the copied instances to customize the shape.
      I would like this number to update when i delete a few sub-components from the Dynamic component, for reporting purposes.
      I am using SpaceDesign to report the components, so a function anyone knows of that I could put into that Plugin to count the instances would also work.
      If anyone can help, my ears are wide open.
