    Unable to use plugin point.rb
    5 Posts 3 Posters 893 Views 3 Watching
      jackeddielove
      This is the message I receive. Can anyone help? Or offer another way to draw points in SketchUp?
      Thanks!
      Jack
      Error Loading File point.rb
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/point.rb;41; parse error, unexpected ',', expecting kEND
      		Sketchup;;set_status_text ("Specify first Point;"), SB_PROMPT
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/point.rb;83; parse error, unexpected ',', expecting kEND
      				Sketchup;;set_status_text ("Click for next point;"), SB_PROMPT
      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/point.rb;84; parse error, unexpected ',', expecting kEND
      				Sketchup;;set_status_text ("Length"), SB_VCB_LABEL
        Where did you get point.rb from ? Probably from the 'crai Depot' - which has the older AND newer versions ?
        Your version is about 4 years old and therefore incompatible with recent versions of Ruby.
        From just the error message I can see that
        Sketchup::set_status_text ("Specify first Point:"), SB_PROMPT
        will cause issues with all of the latest versions of Ruby, because parenthesized arguments must ALL be inside the () AND there should be no space after the calling method.
        Whereas
        Sketchup::set_status_text("Specify first Point:", SB_PROMPT)
        would work.
        It's easily sorted...
        If you look in the SCF 'Plugins Index' for the latest version of it [by the same author] http://forums.sketchucation.com/viewtopic.php?p=95648#p95648
        this version will work OK... [I use it!]
        Make sure you remove the older version because the files have different names and you don't want both of them to load and perhaps clash...
        • Didier BurD Offline
          Didier Bur
          Both EN and FR have been updated today.
          Download them here: http://rhin.crai.archi.fr/rld/plugin_details.php?id=291
          DB
            Didier
            Wasn't the EN version already correct in the later version - you have [had?] two versions of the script by the same author [Matt666] just with different filenames/versions - one's syntax was right, whilst he earlier one was wrong ? ... The older 'point.rb' has no toolbar, while the current 'PointTool.rb' script comes zipped and does.
              Didier Bur
              TIG you're right.
              I updated the latest version (with toolbar) and also made the french version.
              Regards,
              DB
