    Help me convert .dxf to .skp.
    4 Posts 2 Posters 913 Views 2 Watching
    • G Offline
      Gumleguf
      I have this .dxf file that I hope someone with Sketchup Pro will help me convert to .skp.
      Once I'm done drawing I hope you will help me make it a .dxf again.
      It's a .dxf of this amplifier case by hifi2000: http://www.modu.it/slimline.html
      Thanks in advance. πŸ‘
      /Greg
      slim line 2u (1).dxf
        What unit was it made in? (Need to know for proper scaling at import)
        Edit: seems to have been drawn in millimetres. Note that my template is in centimetres so change the units under Model info if you work in other.
        There were some errors SU fixed.
        Here you go. Cookies go to ThomThom.
        dxf.skp
        • G Offline
          Gumleguf
          Thanks Gaieus, for always helping out. You're the greatest. I'll try and work on it later tonight.
          Edit: I believe the .dxf is in mm. I work in mm too.
            Then change my units to millimetres. πŸ˜‰
