    .scene_transition_finished?
    5 Posts 3 Posters 213 Views 3 Watching
      tomasz
      I want to make sure that a transition has been finished between two scenes.
      When a scene is selected Sketchup.active_model.active_view.camera returns immediately the selected scene camera, although current view still changes till it reaches the destination.
      If scenes contain cameras then it can be tested using a view observers and comparing camera eye & direction or maybe even more parameters. What if cameras exactly same in both scenes, but have say a different shadow settings?
      Have someone a good idea how to solve it, that it will work in all cases?
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        Can you get the rendering_options of the scene [page] you are transitioning to... and compare some aspect[s] of the active_view's rendering_options with the equivalent[s] of the scene's rendering_options - e.g. sun-direction or date-time ? and return 'true' only when these are found to be equal ?
        • Dan RathbunD Offline
          Dan Rathbun
          You need to use the FrameChangeObserver
          Weirdly it must be attached to the class via a class method (see example).
          1) The simple example is posted in the Google Sketchup API Blog:
          http://sketchupapi.blogspot.com/2009/07/dynamic-components-that-react-to-scene.html
          2) It is not formmatted correctly (if you cut and paste it from the webpage,) so Todd Burch reformatted it, and posted it here:
          http://www.smustard.com/forum/viewtopic.php?f=9&t=25
          IF you use it, RENAME the class "FrameChangeObserver" to something else, WITHIN your own toplevel namespace.
          Ex:
          module Tomasz # <<-- unique toplevel namespace
            module AnimTest
              class FrameSpy
                # modified callback methods
                # from the Google example
              # your AnimTest code that uses
              # an instance of your FrameSpy class
              # other methods, etc.
            end # module
          end # module
          I'm not here much anymore.
            tomasz
            Right. Unfortunately it is what I would like to avoid.
            Thank you, this is exactly what I was looking for!
            It is really weird. I have checked all observers, but didn't remember this method hidden in SketchUp::Pages!
              Dan Rathbun
              Yup.. it is overlooked because is does not have a protoclass defined, nor it's own page in the API reference.
