    Rotan Chair
    18 Posts 5 Posters 2.3k Views 5 Watching
    • irwanwrI Offline
      irwanwr
      Trying to practise SketchUp with traditional chair made of rotan.
        mwm5053
        Nice model Irwan
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • soloS Offline
          solo
          Sweet model, very well done.
          Can I see the line version? how heavy is it?
          http://www.solos-art.com
          • soloS Offline
            solo
            Nice and low poly πŸ‘
            Too bad the attached model is not textured, I'm guessing the textures were commercial and could not be shared.
            • irwanwrI Offline
              irwanwr
              Ah yes, sorry. Forgot to include the model too.
              Here it is
              kursi rotan.skp
              • irwanwrI Offline
                irwanwr
                No. πŸ˜†
                The texture is self made in Kerkythea. But the textured model size is about 1.38 MB.
                I thought that would be something unacceptable to post in the forum.
                If not, I'll attach the textured model too if you'd like to.
                • soloS Offline
                  solo
                  Please do, as the chair needs those textures to be awesome, I normally make a low resolution proxy texture and in my render app i exchange it for the higher resolution one.
                  • irwanwrI Offline
                    irwanwr
                    That's interesting.
                    How to lower the model size with texture?
                    Are you saying that we should use downgraded image file to use in SketchUp? That makes sense πŸ˜„
                    I'll change the resolution for use next time.
                    Thank you Solo
                    bangku rotan.skp
                    • irwanwrI Offline
                      irwanwr
                      Thank you, Walt.
                      Thank you for the tips, Solo. Thank you very much πŸ‘
                      • hellnbakH Offline
                        hellnbak
                        Really nice work πŸ‘
                        I have a question - why is it that you can see thru the rotan in both photos, but in the first one it casts a solid shadow, but in the second one the spaces between the rotan cast no shadow?
                          I guess the first one is raw SU output and SU cannot handle image transparency but will cast a solid shadow. The second one is already a render.
                          • hellnbakH Offline
                            hellnbak
                            Ah. Didn't realize that one was a render. Thanks.
                            • irwanwrI Offline
                              irwanwr
                              hi Steve,
                              the second one have a texture of a woven rotan. made into Kerkythea material with clip map.
                              • irwanwrI Offline
                                irwanwr
                                that sounds like i failed to make a difference on the look before and after the render πŸ˜›
                                • hellnbakH Offline
                                  hellnbak
                                  Not at all Irwin. I just don't have much of an eye when it comes to rendering (or anything else for that matter) πŸ˜†
                                  • hellnbakH Offline
                                    hellnbak
                                    Nice (now, which one is the rendered one? πŸ˜†)
                                    One thing I noticed, there are a lot of "fighting faces" where the components overlap each other
                                    • irwanwrI Offline
                                      irwanwr
                                      yes, Steve
                                      that's how they tied those rotan bars. there is no other way around to make it smaller, either in file size or poly count. i did that on purpose, trying to mimic how people tied them up. i might try to erase one part. but that might seems to be a not well tied up rotan bar. thought that way i decrease the need to make bigger components, etc πŸ˜›
                                      here's one of the picture i took as an example. i know you are very good at modelling complex things like car. perhaps you can teach me how to do the chair model in a better way.
                                      • irwanwrI Offline
                                        irwanwr
                                        another rotan chair i made for SketchUp practise
                                        kursi rotan 2.skp
                                        Texture Rotan.7z
                                        i've been thinking to upload the materials in KT forum. to ask others opinion and correction on the materials. it's still not worth to share now i'm afraid.
