πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Rotan Chair
18 Posts 5 Posters 1.8k Views 5 Watching
  • I Offline
    irwanwr
    Trying to practise SketchUp with traditional chair made of rotan.
      mwm5053
      Nice model Irwan
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        Sweet model, very well done.
        Can I see the line version? how heavy is it?
          Nice and low poly πŸ‘
          Too bad the attached model is not textured, I'm guessing the textures were commercial and could not be shared.
          • I Offline
            irwanwr
            Ah yes, sorry. Forgot to include the model too.
            Here it is
            kursi rotan.skp
            • I Offline
              irwanwr
              No. πŸ˜†
              The texture is self made in Kerkythea. But the textured model size is about 1.38 MB.
              I thought that would be something unacceptable to post in the forum.
              If not, I'll attach the textured model too if you'd like to.
                Please do, as the chair needs those textures to be awesome, I normally make a low resolution proxy texture and in my render app i exchange it for the higher resolution one.
                • I Offline
                  irwanwr
                  That's interesting.
                  How to lower the model size with texture?
                  Are you saying that we should use downgraded image file to use in SketchUp? That makes sense πŸ˜„
                  I'll change the resolution for use next time.
                  Thank you Solo
                  bangku rotan.skp
                  • I Offline
                    irwanwr
                    Thank you, Walt.
                    Thank you for the tips, Solo. Thank you very much πŸ‘
                    • H Offline
                      hellnbak
                      Really nice work πŸ‘
                      I have a question - why is it that you can see thru the rotan in both photos, but in the first one it casts a solid shadow, but in the second one the spaces between the rotan cast no shadow?
                        I guess the first one is raw SU output and SU cannot handle image transparency but will cast a solid shadow. The second one is already a render.
                        • H Offline
                          hellnbak
                          Ah. Didn't realize that one was a render. Thanks.
                          • I Offline
                            irwanwr
                            hi Steve,
                            the second one have a texture of a woven rotan. made into Kerkythea material with clip map.
                            • I Offline
                              irwanwr
                              that sounds like i failed to make a difference on the look before and after the render πŸ˜›
                              • H Offline
                                hellnbak
                                Not at all Irwin. I just don't have much of an eye when it comes to rendering (or anything else for that matter) πŸ˜†
                                • H Offline
                                  hellnbak
                                  Nice (now, which one is the rendered one? πŸ˜†)
                                  One thing I noticed, there are a lot of "fighting faces" where the components overlap each other
                                  • I Offline
                                    irwanwr
                                    yes, Steve
                                    that's how they tied those rotan bars. there is no other way around to make it smaller, either in file size or poly count. i did that on purpose, trying to mimic how people tied them up. i might try to erase one part. but that might seems to be a not well tied up rotan bar. thought that way i decrease the need to make bigger components, etc πŸ˜›
                                    here's one of the picture i took as an example. i know you are very good at modelling complex things like car. perhaps you can teach me how to do the chair model in a better way.
                                    • I Offline
                                      irwanwr
                                      another rotan chair i made for SketchUp practise
                                      kursi rotan 2.skp
                                      Texture Rotan.7z
                                      i've been thinking to upload the materials in KT forum. to ask others opinion and correction on the materials. it's still not worth to share now i'm afraid.
