    Question: Celtic braid in 3D
    Scheduled Pinned Locked Moved Organic Modelling
    11 Posts 6 Posters 10.0k Views 6 Watching
    • charly2008C Offline
      charly2008
      Hi All,
      I would like to recreate this Celtic fibula. Unfortunately I have no idea how I can construct the Celtic braid in 3D. It would be nice if someone could show me a step to a solution. Especially since the whole is also bowed. Thank you in advance.
      Charly
      Kelten.skp
        mac1
        Take a look at shape bender plugin http://forums.sketchucation.com/viewtopic.php?t=18210
        In addition you could use a photo editor like GIMP to detect edges ( Not necessary here since you have drawn the profile ) and then a raster to vector converter like WinTopo to convert to a vector( So you make it a SU model then. Probably have to go dxf then SU). The results will depend on the quality of the photo.
        • DareDevilD Offline
          DareDevil
          I think you can do it with original tools. Here is my way :
          • Draw the central path on the quarter and draw the section. Use the follow me tool to create the quarter.test1.jpgTest1.skp
          • Duplicate and and rotate, and delete the wrong part for the intersections. Use the face intersection tool and delete the unwanted part.test2.jpgTest2.skp
          • Duplicate and rotate to construct all the model.test3.jpgTest3.skp
            If you want to curve all to make a round fabula, you can use the Sketchy FFD plug-in.
          [EDIT]
          Here is a rounded version made with Shape Bender plug-in
          Test4.skp
          • irwanwrI Offline
            irwanwr
            Monsieur,
            I think you should post more often and provide tutorials for newbies like me.
              There are no intersection on the original ! 💚
              Only Up and down curves! 😉
              Just round your curves ☀
                charly2008
                I thank you all who responded for their help. daredevil, your solution is very close to the original. Pilou, that's the detail I have to solve.
                Sometimes it gets stuck on a small problem.
                Charly
                  charly2008
                  Thank you again for your help. I have modified the model a bit in view of the up and down curves.
                  I lowered both ends by the rotate tool and connected both ends by Curviloft. This is perhaps not the most optimal method.
                  Charly
                    DareDevil
                    Pilou, I was waiting for your remarks 💚 💚
                    OK ! To make some up and down setup, just use the Sandbox Smoove tool 😎
                    But the model must be made with littler details, so the first path must have more points.
                    test5.jpgTest5.skp
                      charly2008
                      Another "Duh" moment.
                      Charly
                        charly2008
                        I took the model of daredevil and supplemented some elements. It may look not quite like the original but it can still become.
                        • N Offline
                          nomeradona
                          @charly2008 said:
                          looks good to me charly2008
                          visit my blog: http://www.nomeradona.blogspot.com
