    Camera from 3ds max to sketchup
    renderpluginsextensions
    2 Posts 2 Posters 2.8k Views 2 Watching
    • G Offline
      garcia_davewarren
      is there a posibilities that camera from 3ds max can be imported to sketchup? thanks a lot.
        brodie
        I don' think there's any way directly but you should be able to hack something together. This is the first thing I'd try.
        In 3ds max get the xyz coordinates of both the camera and the target and draw a line from one point to the other. Then export that line as 3ds or dae and import it into SU. Then you should be able to use the Position Camera tool selecting first the camera location end of the line and then the camera target end of the line. Just make sure your lens size (35mm, 55mm, etc.) matches the 3ds max camera as well.
        -Brodie
