    What happens when....
    71 Posts 14 Posters 4.7k Views 14 Watching
      Lets say you drill a hole through the centre of the planet (ignoring the fact that there is heat to contend with)
      Then you jump in the hole. Will you fall out the other side?
        Yes. I do not even belive that Aussies do not fall off the planet. ๐Ÿ˜’
        • soloS Offline
          solo
          If the heat does not melt you the pressure will crush you.
          http://www.solos-art.com
            incorrect....next opponents
              • andybotA Offline
                andybot
                no. You'd have to go faster than terminal velocity to get through.
                ...though in a vacuum, yes.
                Aw damn, already shot down. Oh well.
                • gillesG Offline
                  gilles
                  If gravity attracts you to the center of the earth, you should stop right there.
                    ooohhhh....go on.....
                    Would fall out the other side?
                    • gillesG Offline
                      gilles
                      Just stuck on center like a magnet.
                        You're saying that when you jump in you stop at the centre and don't exit the other side?
                        If so incorrect
                          Ignoring the actually insurmountable issues of heat/pressure/radiation/forces etc... ๐Ÿ˜ฎ
                          And assuming that both ends of the hole are the same distance [to within a few meters] from the center of gravity of the earth... ๐Ÿ˜ฒ
                          If you did jump in you would fall, fall, fall... accelerating 'down' towards the center under the force of gravity [assuming 'air-resistance' you'd reach a terminal velocity - like a sky-diver], then you'd pass through the very center, and because of your momentum you would continue 'up' towards the other end of the hole... However, because you are now going against the force of gravity you'd decelerate, but you'd almost reach the other end before you slowed to a dead-stop and then started falling back towards the center again. Because your second 'start' is nearer the center then your momentum will be slightly less, as you again pass through the center and approach the other end... this time your trajectory is reversed a little nearer to the center... This cycle repeats with you falling back and forth, but getting progressively nearer the center with each reversal of trajectory. Eventually the reversals will become so frequent that you will effectively be oscillating around the center by an insignificant amount; theoretically after long enough had elapsed you might become stationary at the center, but in practice there are so many variable factors I suspect that you would never quite 'stop'...
                          Note: if you were agile enough... on the first 'fall', just as you approached the other end and slowed to a standstill you could 'grapple' onto the tunnel's wall just below the rim, so with a little climbing 'up' you could pop out at the other end... but I suspect you'd be a bit knackered by then [if not dead] !!!
                          ๐Ÿค“
                          • gillesG Offline
                            gilles
                            I can't prove it as I'm not physician, but if it is the center that attracts you if you pass beyond due to acceleration, you should be attract back?
                            • gillesG Offline
                              gilles
                              by TIG on Sat Jan 28, 2012 7:54 pm
                              Better said that I could, english isn't my native language ๐Ÿ‘
                              • gillesG Offline
                                gilles
                                Rich are you still here?
                                  @TIG
                                  We have a winner ๐Ÿ‘
                                  @Gilles
                                  You had the right idea.
                                  Another one?
                                  • gillesG Offline
                                    gilles
                                    Go on ๐Ÿ‘
                                      If a vehicle is travelling faster than the speed of light what happens when it turns it's headlights on?
                                      • gillesG Offline
                                        gilles
                                        The speeds are added.
                                          So if you were travelling next to the vehicle at the same speed would you see the light on of off?
                                          • gillesG Offline
                                            gilles
                                            They are on.
                                            • 1 / 4
