    [Plugin Library] Win32API and Win32OLE so files
    21 Posts 4 Posters 21.5k Views 4 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Windows ONLY (Do NOT install on Mac!)
      Not a plugin. These files may be required by other plugins.
      The plugin author should list either of these files as a dependancy, if you need them:
      • Win32API.so
      • Win32OLE.so
      ( You do not need these if you have a full Ruby install, and pushed the paths to it's lib dirs into the $LOAD_PATH array.)
      SketchUp 2014
      • Ruby v 2.0.0 - patchlevel 247
      • win32ole.so file is included
      • Win32API.rb file is included, which is a wrapper into the newer DL library, but allows the older WIn32API style calls.
        Do not copy these files from older Ruby versions into SketchUp's "Plugins" folder, for versions 14 or higher !
      SketchUp 8.x, 2013 ( but NOT for higher versions )
      • Ruby v 1.8.6 - patchlevel 287
      • (Files come from the Windows one-click install.)
      SketchUp 6.x, 7.x
      • Ruby v 1.8.0 - patchlevel 0 (initial release)
      I post these because some plugins are distro'ing old versions, or some topics here at SCF have old versions.
      This can be a common place for users to get up to date versions of these files.
      I'm not here much anymore.
        Dan Rathbun
        Since someone is bound to ask, here are the online reference rdocs for these 2 libraries:
        • Win32API rdoc
        • WIN32OLE rdoc
        • sumasterS Offline
          sumaster
          Thank you very much . . . 😉
          Thank you,
          SUmaster
            Dan Rathbun
            Changed first line so it cannot be overlooked, to:
            ... and added 2 more copies of it, for a total of 3 warnings.
            • G Offline
              glro
              i see win32api.so is related to a specific version of sketchup
              is there a new version, available or necessary, for sketchup 2013?
              • Win32API.so
              • Win32OLE.so
              Sketchup 8.0,8.0M1, 8.0M2
              • [attachment=1:2uaslkv3]<!-- ia1 -->v186_p287_so.zip<!-- ia1 -->[/attachment:2uaslkv3]
              Sketchup 6.x, 7.x
              • [attachment=0:2uaslkv3]<!-- ia0 -->v180_p0_so.zip<!-- ia0 -->[/attachment:2uaslkv3]
                Dan Rathbun
                @glro said:
                I see win32api.so is related to a specific version of SketchUp ...
                It is compiled with a specific version of Ruby.
                @glro said:
                ...is there a new version, available or necessary, for SketchUp 2013?
                At the console, check global constants:
                RUBY_VERSION
                and
                RUBY_PATCHLEVEL
                You'll see SketchUp 2013 is still the same as v8 (on the PC.)
                • G Offline
                  glro
                  RUBY_VERSION
                  and
                  RUBY_PATCHLEVEL
                  thank you for answering
                  I was wondering about Ruby version for sketchup 2013, because win32API.so gives an error message in sketchup 13
                  require "Win32API"
                  or
                  require 'Win32API.so'
                  or
                  require 'Win32API'
                  seems not to be compatible with sketchup 2013
                    Dan Rathbun
                    (1) where is the so file on your machine ?
                    (2) please post the error message
                      swajime
                      Thank you Dan for this. I've tried starting with http://stackoverflow.com/questions/1120225/ruby-and-accdb-ms-access but I am getting an error:
                      connection = WIN32OLE.new('ADODB.Connection')
                      Error: #<NameError: (eval):27: uninitialized constant WIN32OLE>
                      Can you please help me to get started with opening a simple database myDatabase.accdb ?
                        swajime
                        I have this directly in the SketchUp ruby console:
                        require 'win32ole'
                        true
                        if defined?(WIN32OLE); connection = WIN32OLE.new('ADODB.Connection'); end
                        Error; #<WIN32OLERuntimeError; (eval);27;in `initialize'; unknown OLE server; `ADODB.Connection'
                            HRESULT error code;0x800401f3
                        The link you put up did not come through.
                          Dan Rathbun
                          The original links in the 2nd post still work.
                          (It's just that the editor has decided to encode pasted URLs, suddenly.)
                            Dan Rathbun
                            I suggest starting a new (if there is not one,) topic in the Developers Forum.
                              swajime
                              Thank you. I did as you said and started a new topic http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=55202%26amp;e=0.
                                Dan Rathbun
                                Did you first have the load statement:
                                require("win32ole")
                                or require("win32ole.so")
                                Then you can test if the class was defined, via:
                                 # more code ...
                                There is a chapter on WIN32OLE in:
                                [doc] Programming Ruby (The "Pick-Axe" Book)
                                  Dan Rathbun
                                  Did you see the link ?
                                  • Win32API rdoc
                                  • WIN32OLE rdoc
                                    Dan Rathbun
                                    Sysops have fixed the editor URL links (above.)
                                    • G Offline
                                      glro
                                      1: in the plugins folder of sketchup
                                      2:win32API.so error message
                                      • G Offline
                                        glro
                                        sorry
                                        problem solved
                                        you were right: win32API.so and sketchup 2013 are compatible
                                        thank you
                                          Dan Rathbun
                                          @glro said:
                                          sorry ... problem solved
                                          Yes I have no problem loading it.
                                          What was your issue ?
                                          • G Offline
                                            glro
                                            still don't know
                                            changed something (don't know what) and the problem disappeared
                                            thank you for your comments
                                            • 1 / 2
