    [Plugin Library] Win32API and Win32OLE so files
    21 Posts 4 Posters 22.1k Views 4 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @glro said:
      seems not to be compatible with sketchup 2013
      (1) where is the so file on your machine ?
      (2) please post the error message
      I'm not here much anymore.
        swajime
        Thank you Dan for this. I've tried starting with http://stackoverflow.com/questions/1120225/ruby-and-accdb-ms-access but I am getting an error:
        connection = WIN32OLE.new('ADODB.Connection')
        Error: #<NameError: (eval):27: uninitialized constant WIN32OLE>
        Can you please help me to get started with opening a simple database myDatabase.accdb ?
          swajime
          I have this directly in the SketchUp ruby console:
          require 'win32ole'
          true
          if defined?(WIN32OLE); connection = WIN32OLE.new('ADODB.Connection'); end
          Error; #<WIN32OLERuntimeError; (eval);27;in `initialize'; unknown OLE server; `ADODB.Connection'
              HRESULT error code;0x800401f3
          The link you put up did not come through.
            Dan Rathbun
            The original links in the 2nd post still work.
            (It's just that the editor has decided to encode pasted URLs, suddenly.)
              Dan Rathbun
              I suggest starting a new (if there is not one,) topic in the Developers Forum.
                swajime
                Thank you. I did as you said and started a new topic http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=55202%26amp;e=0.
                  Dan Rathbun
                  Did you first have the load statement:
                  require("win32ole")
                  or require("win32ole.so")
                  Then you can test if the class was defined, via:
                   # more code ...
                  There is a chapter on WIN32OLE in:
                  [doc] Programming Ruby (The "Pick-Axe" Book)
                    Dan Rathbun
                    Did you see the link ?
                    @dan rathbun said:
                    Since someone is bound to ask, here are the online reference rdocs for these 2 libraries:
                    • Win32API rdoc
                    • WIN32OLE rdoc
                      Dan Rathbun
                      Sysops have fixed the editor URL links (above.)
                        glro
                        1: in the plugins folder of sketchup
                        2:win32API.so error message
                          glro
                          sorry
                          problem solved
                          you were right: win32API.so and sketchup 2013 are compatible
                          thank you
                            Dan Rathbun
                            @glro said:
                            sorry ... problem solved
                            Yes I have no problem loading it.
                            What was your issue ?
                              glro
                              still don't know
                              changed something (don't know what) and the problem disappeared
                              thank you for your comments
                                Dan Rathbun
                                ❗ FYI
                                SketchUp 2014
                                • Ruby v 2.0.0 - patchlevel 247
                                • win32ole.so file is included
                                • Win32API.rb file is included, which is a wrapper into the newer DL library, but allows the older WIn32API style calls.
                                  %(#BF4000)[Do not copy these files from older Ruby versions into SketchUp's "Plugins" folder,
                                  (or any of SketchUp's folders,) for versions 14 or higher !]
