    [Plugin Library] Win32API and Win32OLE so files
    21 Posts 4 Posters 22.7k Views 4 Watching
      swajime
      Thank you Dan for this. I've tried starting with http://stackoverflow.com/questions/1120225/ruby-and-accdb-ms-access but I am getting an error:
      connection = WIN32OLE.new('ADODB.Connection')
      Error: #<NameError: (eval):27: uninitialized constant WIN32OLE>
      Can you please help me to get started with opening a simple database myDatabase.accdb ?
        swajime
        I have this directly in the SketchUp ruby console:
        require 'win32ole'
        true
        if defined?(WIN32OLE); connection = WIN32OLE.new('ADODB.Connection'); end
        Error; #<WIN32OLERuntimeError; (eval);27;in `initialize'; unknown OLE server; `ADODB.Connection'
            HRESULT error code;0x800401f3
        The link you put up did not come through.
        • Dan RathbunD
          Dan Rathbun
          The original links in the 2nd post still work.
          (It's just that the editor has decided to encode pasted URLs, suddenly.)
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            I suggest starting a new (if there is not one,) topic in the Developers Forum.
              swajime
              Thank you. I did as you said and started a new topic http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=55202%26amp;e=0.
              • Dan RathbunD
                Dan Rathbun
                Did you first have the load statement:
                require("win32ole")
                or require("win32ole.so")
                Then you can test if the class was defined, via:
                 # more code ...
                There is a chapter on WIN32OLE in:
                [doc] Programming Ruby (The "Pick-Axe" Book)
                • Dan RathbunD
                  Dan Rathbun
                  Did you see the link ?
                  @dan rathbun said:
                  Since someone is bound to ask, here are the online reference rdocs for these 2 libraries:
                  • Win32API rdoc
                  • WIN32OLE rdoc
                  • Dan RathbunD
                    Dan Rathbun
                    Sysops have fixed the editor URL links (above.)
                    • G
                      glro
                      @dan rathbun said:
                      @glro said:
                      seems not to be compatible with sketchup 2013
                      (1) where is the so file on your machine ?
                      (2) please post the error message
                      1: in the plugins folder of sketchup
                      2:win32API.so error message
                      • G
                        glro
                        sorry
                        problem solved
                        you were right: win32API.so and sketchup 2013 are compatible
                        thank you
                        • Dan RathbunD
                          Dan Rathbun
                          @glro said:
                          sorry ... problem solved
                          Yes I have no problem loading it.
                          What was your issue ?
                          • G
                            glro
                            still don't know
                            changed something (don't know what) and the problem disappeared
                            thank you for your comments
                            • Dan RathbunD
                              Dan Rathbun
                              ❗ FYI
                              SketchUp 2014
                              • Ruby v 2.0.0 - patchlevel 247
                              • win32ole.so file is included
                              • Win32API.rb file is included, which is a wrapper into the newer DL library, but allows the older WIn32API style calls.
                                %(#BF4000)[Do not copy these files from older Ruby versions into SketchUp's "Plugins" folder,
                                (or any of SketchUp's folders,) for versions 14 or higher !]
