    [Plugin Library] Win32API and Win32OLE so files
    21 Posts 4 Posters 22.5k Views 4 Watching
      glro
      @dan rathbun said:
      @glro said:
      I see win32api.so is related to a specific version of SketchUp ...
      It is compiled with a specific version of Ruby.
      @glro said:
      ...is there a new version, available or necessary, for SketchUp 2013?
      At the console, check global constants:
      RUBY_VERSION
      and
      RUBY_PATCHLEVEL
      You'll see SketchUp 2013 is still the same as v8 (on the PC.)
      thank you for answering
      I was wondering about Ruby version for sketchup 2013, because win32API.so gives an error message in sketchup 13
      require "Win32API"
      or
      require 'Win32API.so'
      or
      require 'Win32API'
      seems not to be compatible with sketchup 2013
      • Dan RathbunD Offline
        Dan Rathbun
        (1) where is the so file on your machine ?
        (2) please post the error message
        I'm not here much anymore.
          swajime
          Thank you Dan for this. I've tried starting with http://stackoverflow.com/questions/1120225/ruby-and-accdb-ms-access but I am getting an error:
          connection = WIN32OLE.new('ADODB.Connection')
          Error: #<NameError: (eval):27: uninitialized constant WIN32OLE>
          Can you please help me to get started with opening a simple database myDatabase.accdb ?
            swajime
            I have this directly in the SketchUp ruby console:
            require 'win32ole'
            true
            if defined?(WIN32OLE); connection = WIN32OLE.new('ADODB.Connection'); end
            Error; #<WIN32OLERuntimeError; (eval);27;in `initialize'; unknown OLE server; `ADODB.Connection'
                HRESULT error code;0x800401f3
            The link you put up did not come through.
              Dan Rathbun
              The original links in the 2nd post still work.
              (It's just that the editor has decided to encode pasted URLs, suddenly.)
                Dan Rathbun
                I suggest starting a new (if there is not one,) topic in the Developers Forum.
                  swajime
                  Thank you. I did as you said and started a new topic http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=55202%26amp;e=0.
                    Dan Rathbun
                    Did you first have the load statement:
                    require("win32ole")
                    or require("win32ole.so")
                    Then you can test if the class was defined, via:
                     # more code ...
                    There is a chapter on WIN32OLE in:
                    [doc] Programming Ruby (The "Pick-Axe" Book)
                      Dan Rathbun
                      Did you see the link ?
                      @dan rathbun said:
                      Since someone is bound to ask, here are the online reference rdocs for these 2 libraries:
                      • Win32API rdoc
                      • WIN32OLE rdoc
                        Dan Rathbun
                        Sysops have fixed the editor URL links (above.)
                          glro
                          1: in the plugins folder of sketchup
                          2:win32API.so error message
                            glro
                            sorry
                            problem solved
                            you were right: win32API.so and sketchup 2013 are compatible
                            thank you
                              Dan Rathbun
                              @glro said:
                              sorry ... problem solved
                              Yes I have no problem loading it.
                              What was your issue ?
                                glro
                                still don't know
                                changed something (don't know what) and the problem disappeared
                                thank you for your comments
                                  Dan Rathbun
                                  ❗ FYI
                                  SketchUp 2014
                                  • Ruby v 2.0.0 - patchlevel 247
                                  • win32ole.so file is included
                                  • Win32API.rb file is included, which is a wrapper into the newer DL library, but allows the older WIn32API style calls.
                                    %(#BF4000)[Do not copy these files from older Ruby versions into SketchUp's "Plugins" folder,
                                    (or any of SketchUp's folders,) for versions 14 or higher !]
