    Windowizer 4 - alphabetical order of materials?
    8 Posts 2 Posters 1.9k Views 2 Watching
    • john2J Offline
      john2
      i'm using windowizer 4 . is there any way to arrange the materials listed in the glass materials in alphabetic order when the drop down menu comes?
        The Windowizer4.rb uses
        matlist = getMaterials().split("|")
        to assemble an collection of the available materials, as an array.
        The getMaterials.rb returns a string of all available material-names, separated by '|'.
        It IS sorted... matNames.sort.join('|') - I don't see the issue ?
        The same sorted list of materials is used for frames and glass ??
        • john2J Offline
          john2
          I don't know ruby..hence i don't know what you're saying πŸ˜•
          here are two screnshots
          http://i.imgur.com/kqYfC.jpg
          http://i.imgur.com/DEY7G.jpg
            Open the Ruby Console and type this word + <enter>
            getMaterials
            It needs to be exactly as it's written [or Copy/Paste]
            It should return a list of Materials in the model sorted by their names [separated by '|'] ?
            It does that for me... and that's the code used inside Windowizer4 too.
            Do you have the current getMaterials.rb [comes from Smustard.com with Windowizer4 ?] ?
            If it doesn't work try this - Copy/Paste this code it should again be sorted...
            matNames=[];Sketchup.active_model.materials.each{|e|matNames<<e.name};matNames.sort
            πŸ˜•
            • john2J Offline
              john2
              getMaterials
              πŸ˜•
              i have one getmaterials and it has this text
              def getMaterials
              model=Sketchup.active_model
              mats=model.materials
              matNames=[]
              mats.each {|e| matNames.push(e.name)}
              matList=matNames.join('|')
              return matList
              no version
              your code [rubymatNames=[];Sketchup.a.......] works but do i need to type this everytime?? cant my plugin be edited by adding a line or two?
                Try this...
                Make a copy of windowizer4.rb - outside of the Plugins folder so it doesn't auto-load and confuse the issue! IF you screw up you can use it to replace the one you about to attempt a recode on !!
                Edit the windowizer4.rb file that's in the Plugins folder using Notepad.exe [or an equivalent plain-text editor - NOT a wordprocessor as that will add formating and break the script !]
                Find the second line containing the text ' getMaterials' [it's around line#299] that says...
                add a '#' to the start of that text thus...
                #matlist = getMaterials().split("|")
                This stops the line of code being read at all.
                Now add this new line of code immediately below it...
                matlist=[];@model.materials.each{|e|matlist<<e.name};matlist.sort!
                This will make the list in the same way that you did manually in the test I gave you [hopefully successfully again], without the need for ' getMaterials' at all.
                The 'wording' is slightly tweaked to suit the script's coding.
                Save/close and restart Sketchup to auto-reload the script.
                See if the materials lists are now properly ordered...
                πŸ€“
                • john2J Offline
                  john2
                  I did the coding sir as you said, im getting the following results.
                  im getting results like all the <> materials first, after that capital words sorted alphabetically,
                  then the [] type ones
                  then with small letters
                  http://i.imgur.com/4fH7J.jpg
                  will that be the order ? i mean SU is giving importance on brackets rather than letters
                    This isn't Sketchup's doing. 😲
                    The 'sort' algorithm in Ruby does a straightforward alphanumeric sort of the 'words'.
                    It depends on ASCII code numbers etc...
                    So punctuation (! # etc), then numbers , then some punctuation (<> etc), then uppercase letters, then some other punctuation ([] etc) and then lowercase letters etc.
                    Paste this in the Ruby Console to see what I mean:
                    ["zebra","Zebra2","456","123","ABC","[xyz]","[abc]","abc","<abc>","#1"].sort
                    The 'bracketry' around the material names is to do with how they have been created/imported etc - read the Help section on this...
                    You could use the 'display_name' [what's show in the Materials Browser] in the sorted list and then have a 'look up table' that uses the materials' 'display_name' against the actual Sketchup 'name'... BUT that some extra coding that RickW needs to do to his script.
                    Why not PM Rick and explain the issues...
                    Windowizer4 is a 'commercial script' - therefore posting too much of its code is 'not on' - I even worried about that one line tweak a gave you !
