    Follow vs Me Tool
    8 Posts 5 Posters 485 Views 5 Watching
    • N Offline
      NickGenerator
      I am trying to make three cylinders meet in a beautiful, rounded corner, but things look horrible.
      Is there a plugin for stuff like that?
      • Jean LemireJ Offline
        Jean Lemire
        Hi Nick, hi folks.
        See this SU file for ideas.
        3 cylinders meeting at a corner.skp
        • gillesG Offline
          gilles
          This my attempt as you got V8 so got Outershell.
          tubes-corner.skp
          • N Offline
            NickGenerator
            Thanks for the explanation. Looks like real work.
              Jean Lemire
              Hi Gilles.
              Good trick.
              Thanks.
              Hi Nick.
              The methods I show are to get you a feeling of what is possible with sketchUp native tools.
              Gilles developped a relatively fast method, also using native tools.
              Just ideas.
              • charly2008C Offline
                charly2008
                @jean lemire said:
                Hi Gilles.
                Good trick.
                Thanks.
                Hi Nick.
                Just ideas.
                With a little reworking it works also well with the FollowMe tool.
                Charly
                • N Offline
                  NickGenerator
                  I totally get the point, but I need all my time for "intersect with model". 😆
                  • Alan FraserA Offline
                    Alan Fraser
                    Another variation of these methods is to produce the rounded corner first by using Rounded Corners in 3D on one corner of a cube. Then just delete everything you don't need and create a circle then a cylinder from any of the quadrants that form the edges of the cornerpiece. Mate 3 copies of this cylinder onto the rounded corner and use the OuterShell command. Explode the resulting group and you're pretty much done.
                    3D Figures
