    Getting unexpected result when setting material color
    7 Posts 4 Posters 362 Views 4 Watching
      marksolberg
      When I run this script I get a range of blue colors applied to the components. I'm trying to get a range of red colors. I've checked and double checked my colors to make sure I have the right hex code for them.
      mod=Sketchup.active_model
      ents=mod.entities
      sel=mod.selection
      my_colors=[0xFF3300,0xFF4719,0xFF5C33,0xFF704D,0xFF8566,0xFF9980]
      i=0
      ents.each do |e|
        if e.is_a? Sketchup;;ComponentInstance
             e.material = my_colors[i]
              i+=1
      What am I missing?
      Thanks,
      Mark
      • Dan RathbunD Offline
        Dan Rathbun
        Sketchup uses RGBA color integers (which are read from right to left, least significant first.)
        ie: 0xAABBGGRR
        Here's an old post with some code snippets I haven't done much with in a long while:
        [Ruby Extension] for Sketchup color integers
        I'm not here much anymore.
          Your codes are hex for 'blues' ?
          Get some 'red' ones πŸ˜•
          http://www.rgbhex.com/index.php
            marksolberg
            Thanks,
            I was using what I thought was normal notation for colors i.e. 0xFF9900. Sketchup expects 0x0099FF. Who'd a thunk.
            Mark
              ie: 0xAABBGGRR
              I get errors in 0xAABBGGRR
              Error: #<RangeError: (eval):155:inmaterial=': bignum too big to convert into long'>
              I can only get 0xBBGGRR to be accepted.
                Dan Rathbun
                Yes well we all know there is much room for improvement in the API.
                As I recall, only materials took (or used to take,) alpha. Colors did not.
                But I remember a change in alpha during the v8 beta cycle. (Have to refer to the release notes.)
                An alternative for colors (since they also take an Array argument,) is to set them like:
                mycolor = Sketchup::Color.new( [0xFF,0x33,0x00] )
                or
                my_matl.color = [0xFF,0x33,0x00]
                ... which is read as [red,green,blue]
                  They do, and did. It's just that they wheren't used until SU let you draw to the viewport with transparency.
